P700 Tire alignment
Shadmejean1
39
9
Indiana
I have posted this before but now I can't find it. My right front tire is wearing really bad on the outside. Any easy ways to check my alignment ? Is this called toe in or toe out ?
Gator
Gator
The Most Unknown Member
2,489
10,470
Louisiana
You need level ground. Preferably concrete.
Squat down in front of it. Is that tire leaning out? (positive camber)
You can adjust the Camber and toe-in/toe-out really easy.
Several of us had problems with the tie-rod or steering linkage loosening.
I set mine with about 1/8" negative camber. (the bottom is about 1/8" further out than the top)
I tried to set a zero toe-in.
Reactions: Mudwing
M_Walker
15
32
My right front tire was wearing quickly on the outside also. The camber was ok, but the toe-in was 1.25". I never checked the alignment until mounting new tires and noticing that it didn't want to hold a straight course when driving. I ended up with the toe-in at 1/8" and it handles much better now. I've read of quite a few others finding the toe setting way off from the factory.
Chad123
10
Tennessee
Is there any videos out there on how to do the things you all are talking about. Reason why I'm asking is because I am mechanic challenged.
jwfirebird
jwfirebird
927
1,446
western ny
pretty simple should be no problem for any one, you put the weight in it that is normally there, person or people (will be different if just empty) and measure to the same point on the same block front and back the front should be 1/8th inch less than the rear. you take the tie rod off and thread it in or out to adjust it. take the nut off and it is usually tapered so you will have to leave the nut on and bang it out, I usually use a block or something so it doesn't mess up the nut.
M_Walker
15
32
There is no need to remove the tie rod end! Simply loosen the jam nut on the threaded portion of the tie rod and turn the rod in or out of the tie rod end as needed, then tighten the jam nut.
Reactions: Shelly
