P1000 Tire help.
Dodgeman04
15
9
Kentucky
have a 2020 honda pioneer 1000-5 looking at the tusk terrabite tires does anybody know if the 28x10x14s will fit on stock wheels and suspension on front and back without issues or rubbing? I've looked till my eyes hurt lol thanks for any help.
Reactions: TxDoc and Russ989
Russ989
Russ989
22,642
147,257
Yes they will, a spacer lift will help with the scrub.
Reactions: Dodgeman04
Dodgeman04
15
9
Kentucky
So I would need to run wheel spacers correct. Just in front or both front and back or are you talking about a suspension lift?
Russ989
Russ989
22,642
147,257
Spacers won’t hurt, I would do 1.5” on the back and 1” on the front. Yeah, I’m talking about a suspension lift.
Russ989
Russ989
22,642
147,257
Here’s mine. 1.5” and 1” spacers, SATV a-arms front and rear, spacer lift and 30x10-14’s.
E2A3C76B D38A 4A3C B02D CEA407AE91B1
Dodgeman04
15
9
Kentucky
Nice ride. Not really wanting togo that in depth on it yet only had it about 4 weeks aint even got my roof in yet lol. But the factory 4ply tires have got togo.
Reactions: Russ989
Dodgeman04
15
9
Kentucky
Use it on the farm and trail ride and its just matter of time before getting flats start.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Yeah they are pretty horrible, don’t blame you.
TripleB
TripleB
15,251
136,235
Caryville, Tennessee
Th
They will fit. Your machine will be 1 inch wider in the front and 1 inch more narrow in the rear. Which is 2 inches different front to back. Your can leave it like that and it will be fine or you could add 1 inch wheel spacers in the rear. 1 inch on each side in the rear would make it even front to back. they might scrub some at full compression. My 28 inch evolutions scrubbed some in the front. I place 1 self tapper though the inner fender on each side where it was hitting. Fixed the problem. The terrabites might not hit at all.
Reactions: Hp1 and Dodgeman04
Redmoon
Redmoon
265
456
Prescott Az.
Getting ready to install 28x10x14 Motoclaws on my 1000-5 with RB3 spacers.
TxDoc
TxDoc
2,245
7,605
TEXAS 🇨🇱
photos.app.goo.gl
I have a 2020 1000-5 stock with Super ATV Intimidator tires 28x10-14. 10mm offset wheels and no rubbing.
Reactions: TripleB
hurld
hurld
129
159
I have Quadboss 846's (28x10x14) which are similar to the terrabite, but have a flatter tread profile. I have zero rubbing. I mounted them on the factory rims & added 1" wheel spacers on the rear so the width was the same front & back. Ad67cd73da2b717f8b209f324b89a3aa
Sent from my SM-N960U using Tapatalk
Reactions: TripleB
Hp1
19
I put the tusk 28-10-14 wheels/rims on my stock machine, and it doesn't rub.
I did install 1.5 spacers on the back (which turned out good) because the 1" were on backorder.
Probably get a little less mud to the back of the head with 1" spacers🤔
KIMG0891
Reactions: TripleB
TripleB
TripleB
15,251
136,235
I ended up moving my 1 inch spacer to the front and put 2 inch in the rear, so i would be a little wider for stability. 1 ride like that and i had to order mudbusters because it was putting way too much mud in the cab.
Dodgeman04
15
9
Kentucky
thanks for all the info just decided to go with factory size but I love the terrabite tires drives and rides way better than before.
