Tire wear.
SgtBrown
SgtBrown
Hyndman, PA
I have a 2019 700-4 Pioneer. I do mainly blacktop and dirt road riding. Rarely been in 4 wheel drive. The passenger front factory tire was a racing slick in less than 500 miles. The other 3 was still like new. At the advice of the dealership. I replaced all 4 with radial 10 ply DOT approved tires. They have just over 200 miles on them. Still the passenger front is wearing. Anyone else having a problem with just 1 front tire wearing?
SgtBrown
SgtBrown
Hyndman, PA
Need to align it.
I've had it to the dealership twice. They say nothing is wrong. They tried to tell me it's from blacktop riding first time. But I mentioned why is it only 1 tire. So then they tried to say it was from driving in 4 wheel drive on blacktop. It never goes any where to use 4 wheel drive. So then they tried to tell me the tire pressure was off. I check pressure before every ride. That's when they told me the factory tires are not designed to last. So I bought the radials. DOT approved. It started to show signs of wear in less than 200 miles. Took in back in to dealership. This time I told them I want it fixed or replaced. They said they adjusted the alignment. I swapped the front tires. Keeping track of miles now. Only 75 miles since alignment. But it still wants to pull right.
60,382
Sounds like a pretty awful dealer. You could try bringing it by a tire shop and have them align it, but that'll probably run you $75-$80.
weelad
weelad
85
583
83
West Michigan
A vehicle will usually pull to the side that has the issue which you verified and it is usually because that wheel has been pushed back (i.e. bent lower control arm or other part). If just tow in was off it would wear both front tires the same so I would suspect that right front wheel is back or has a worn or bad ball joint. With the steering wheel pointing straight ahead measure the wheelbase by measuring center to center of the left side wheels and then measure the right side and see if it is shorter.
Reactions: Isaiah and TripleB
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Measuring tape on the front and backside of the tire . Get the front about 1/8-1/4 less than the rear. A set of ratchet straps and 2x4 or somthing flat makes it really easy. Adjust move it forward then double check
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
1600 miles on the tires on the right and all of them look the same doing this. Pavement dirt roads mostly with about 200 miles worth of actual mud holes 3fe652b45b8f76bdd90a9a361dc490d9
Danno887
Pennsylvania
Did you ever get an answer on this? Mine is doing the same thing. Almost 900 miles mostly gravel and oil/chip road. Passenger front has about twice as much wear as the drivers side and outside of passenger tire does seem worse then inside. Both tires at ~7psi.
edit: I do have toe plates ordered waiting for them to arrive to verify the amount of toe in the front end
FeelinRecless
FeelinRecless
182
549
Just over 1000 miles on mine, good mix of pavement, pack dirt, off-road. Both my front tires are extremely worn and a funky pattern. I think they’re just a garbage rubber compound tire.
FeelinRecless
FeelinRecless
182
549
