P700 Tire wear
FeelinRecless
FeelinRecless
182
549
I will try and get a pic when I have a chance, but, 700 or so miles, and my front tires have some odd wear. All stock. 2020 700-4. Middle and sides are fine, sections in between are wearing down. Only on the fronts. Anyone else see this?
Reactions: Backwoods
Backwoods
Backwoods
35,248
357,922
Douglasville ga
Check alignment and tire pressure
Reactions: Mudwing
FeelinRecless
FeelinRecless
182
549
I will, but the odd thing, both sides wearing the same. And like I said, new machine, about 700 miles total.
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
Here’s 1720 miles. Mostly mud. Some asphalt. 😉I’m with Backwoods. Check those things out. 😎
Mopower58
Mopower58
Unburdened by what has been!
79,849
709,077
Crystal Springs,Ms.
The toe-in was normally off on the P1K's when new. Not sure about the 700, @Mudwing and @Backwoods would be a lot more helpful on that.
Reactions: Mudwing
Backwoods
Backwoods
35,248
357,922
Douglasville ga
Its fairly common for them to be off . I had the dealer check mine when I bought it. Sometimes their prep is not thorough.
FeelinRecless
FeelinRecless
182
549
Not saying its not alignment, but I have ever seen tires wear on the inside and outside, on both sides, but not down the center.
82907295 C6F0 4F63 8D13 DF0100ACCA04
the pic doesn’t show it very well. But it’s also both front tires equally.
Backwoods
Backwoods
35,248
357,922
Douglasville ga
That is odd, I have never saw wear.pattern like that either. I'm probably wrong but I'm guessing under inflation. Do what I would do Google odd tire wear patterns
Reactions: Mudwing
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
Same thing here at about 500 miles on a 4 month old 2020. Chopped to hell and back. Mostly asphalt and gravel with some woods and pasture. Went ahead and replaced them since I was doing much more road riding than I expected.
20200802 173049
20200802 173033
FeelinRecless
FeelinRecless
182
549
If you under inflate, the edges wear normally. The edges aren’t wearing down a lot. It’s between the edges and center. I plan to go to a less aggressive tire next. At least I’m not the only one who had it.
Backwoods
Backwoods
35,248
357,922
Douglasville ga
I hope you get it resolved I now it.can be aggravating try to figure it out.
livefromthetree
livefromthetree
466
1,309
27" terrabites just put on a few days ago. Sit great, much quieter on the road and hopefully give me a couple thousand miles
20200817 195800
  • Love
