P1000 Tire/wheel questions
Jeffro
106
47
Louisiana
I'm wanting to get some new tires and wheels for the P1000 and have a few questions. I think I want the 28" Blackwater Evolution on either HD3 or HD7 14" wheels. I want a little bigger, more aggressive, and better all around tire than the stock tires, and I want something that will fit without a lift. I will be mostly trail riding on rocky terrain in Arkansas, gravel and dirt, and a little mud here in Louisiana but nothing too extreme. From what I've read these sound like a good choice.
1) Does anyone have pictures of this combo?
2) 28x10-14 all around will fit with no rubbing without a lift right?
3) What are the pros/cons of having the same width all around versus 9" in front and 11" in rear?
jasontjames
jasontjames
146
174
Melissa, TX
I have 28x10-14 Rocktane XD-K's on 14" STI HD Beadlocks with no lift and have had no issues with rubbing. The Rocktanes run true to size, but from what I have gathered the Evo's run a little small. Some of the guys that have the 28" Evo's can speak to that better than I can. I have the same size all around. I like that for the purpose of being able to rotate the tires and being able to have a spare that will go onto any wheel position.
What offset are you looking at? Mine are 5+2 and the front width is about 1" wider than the rear. That increases the amount of mud you have to dodge but not to a great extent.
The 28" EVOs will be true to size and mine measured 28.25".
One thing to think about is the weight of this machine and how much sidewall you will have. Personally on the pioneer 1000 I would use a 12 inch wheel in a 28 inch tire. That would give you more cushion to protect the wheel from breaking. I only mention that because you said that you'll be riding in rocky terrain.
I know someone that has 30 inch Evo's on 12 inch wheels and they ride very good.
Signature:
QUOTE by Eltobgi, Honda...Strong enough for the Farm!...Dependable enough for everything else!
Reactions: dotman1 and drfubar
Jeffro
106
47
Louisiana
Yeah, I read about the benefit of rotating and having a spare, any others advantages or more importantly, disadvantages? Why are stocks always more narrow in the front?
I guess 5+2, I don't really know much about the offset and what that does. 5+2 is the only option when I select those wheels on Rocky Mountain ATV.
Jeffro
106
47
Louisiana
Signature:
Good point, I hadn't thought of that. I just like the way the 14" wheels look with the 28" tires.
Reactions: joeymt33
Jeffro
106
47
Louisiana
Anybody have any input as to why stock tires are more narrow in the front and any disadvantage to going with the 10" all around? Or anybody have the Blackwater/HD3 combo? I'm about ready to pull the trigger on a set, just trying to decide between 10" or 9" and 11". Want to make sure the 28x10 won't rub without a lift.
I think you'll be fine with 10's all around. You will probably want A spacer for the back to make the rear tires the same track as the front.
Jeffro
106
47
Louisiana
Would I need a 1" spacer?
The rear hubs are set in approximately 1" more narrow that the front. Honda uses different offset wheels front and rear. You don't need to get spacers but your rear track will be two inches more narrow total. It just bugged me.
Reactions: sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Might want to consider a set of mudbusters. I have 30" Evos on 14" rims with 5+2. The fronts will throw mud all over you. Installed the flares and no more problems. You'll love those tires. They work great in just about anything you throw at them.
Reactions: sharp
sugarray
sugarray
Is this a game show?
661
1,257
WV
Could you run 5+2 on front and 4+3 on the rear to bring it out a little, or am I thinking wrong? Not even sure you could find the same wheel with 2 different off sets with lug pattern correct.
You could do that if you could find a matching wheels with different backspacing.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That's what I ran into with the Hd6s. Only offered in the 5+2.
jasontjames
jasontjames
146
174
Melissa, TX
Vision Wheels has 14x7 and 14x8 options with a lot of their wheels. The 14x7 wheels are 4+3 and the 14x8 are 4+4. You would have different wheels widths from the back but that would give you the same width for the front and rear axles.
Jeffro
106
47
Louisiana
Anybody have the Maxxis Carnivores? They look good and are an 8 ply radial also.
edstoy
edstoy
25
31
Middle Georgia
i like the tensor regulators on the 4+3 configuration. 28x10x14
IMG 1728
Reactions: joeymt33
