To SLIME or NOT TO SLIME!
67,170
Before both passanger tires would go flat in under a weeks time.
Installed and set to 14 psi on the 10th.
Day 11 test results.
- Front tire has held at 13 psi.
- rear tire had a good tire pinch but it held at 9psi.
I think it needs more ride time to coat the inside.
Put 1 mile on them today.
Aired back up to 14 psi.
44fa37489bb50c505fb2f21045460724613fea2da53c64a94a579374959b00c0
Razorback
Razorback
397
999
Van Buren, AR
I use this stuff. It works. Half a bottle per tire, no flats since and it sealed up my bead leaks
MULTI SEAL 20130 Tire Sealant with Kevlar (Sportsman Formula), Great for ATVs, UTVs / Side-by-Sides, Golf Carts, Dirt Bikes, Off-Road-Only Jeeps and more, 1-Pack (32 oz.) https://www.amazon.com/dp/B071QWCW42/?tag=sxsweb24-20
I bought a few bottles of this. Is it best to put it in immediately before riding or is it ok for it to sit a couple of days?
nitzo
nitzo
521
1,105
East Coast, Florida
Why is it that after reading through a thread like this and going years without the product, you suddenly feel the uncontrollable urge to run out and purchase the product because...Well because you know you can’t live without it! Lol.
Getting some next trip to Walmart:(
ROFLMAO..........I just ordered some.
Mudder
Mudder
NTC Ambassador of Walls
11,690
88,472
Slime worked for years in a Kubota tractor front tire, tire shop charged extra for rim cleaning when it finally wore down. Also fixed a leak in large water filled rear tire, 8 yrs and still holding.
nitzo
nitzo
521
1,105
East Coast, Florida
I just put this in today, it's really easy to do, no mess at all.
I used a whole bottle per tire, then I inflated the tires to normal psi plus 5 lbs (hell, I don't why I did this), then drove around for 1/2 hr or so(not sure why on this either:D), the stuff stays liquid and I figure one rotation and the inside of the tire is coated.
Razorback
Razorback
397
999
Van Buren, AR
I installed 1 bottle in each tire the night I asked. Had 1 tire that always leaked and guessed it was leaking from the beadlock, but never could find a leak. 70+ miles of rough trails over 2 weekends and no leaks.
