Multi Tractors & SxS = Workhorses
Backwoods
Backwoods
31,859
327,821
Douglasville ga
like there petals alot better than new holland, like deere ones. mine has the hydro but the petal is a rocker, i had a mower at work that way too always hated that trying to work it with boots is a pain. always thought 30-40h compact was a decent size, so that be a 1540? thats why i got mine has the clearance and can run 6ft stuff. we have alot of mud and trees, light and small is good most of the time. never had or operated an orange one, one of the guys in my club has one its between there subcompact and mine, tlb, but he just uses is for mowing his yard mostly. the only thing broke so far was the hydraulic fitting and he said they came right out and changed it. he dont work it though but it was nice clearing trails with that
Yeah it's a 1540 , the pedals are separate it's very easy to drive you know your tractors quite well
Backwoods
Backwoods
31,859
327,821
Douglasville ga
I end up using the Kubota hydrostatic pedal “cruise control” lock more than I thought when bushhogging pasture. Also finally replaced the seat with a higher back support one from Northern Tool, but did have to buy 4 short metric bolts to fit. Alot more comfortable, should have done it sooner. 1000 hrs just rolled up.
Me to I like the cruise control especially when bushhogging, do most of it with the 3645 and a 2615 fifteen footer.
Backwoods
Backwoods
31,859
327,821
Douglasville ga
It's a great time saver and cuts really clean
20190413 194506
11,296
83,820
Amazing what a little tractor can do. Harvesting dirt from back of property to build up pasture riding track. Needless to say, it was a LOT of bucket scoops. Did some bushogging and making new trails in woods today.
A97E025E E774 4B84 A8AA 9F6351854BD5 3C1B1848 A265 4695 9DF6 D107C22CE81A 11560CEE A13C 4D62 9806 994AB265F145 78D87225 3F3B 420F BE74 F66A04245433
X
xmountaineer
23
72
WV
I couldn’t live without my tractor. Ventrac 4500z. Dual wheels, bucket with grapple, 68” brush hog, 72” finish mower, 72” blade, stump grinder, power rake (Harley rake).
IMG 9609
IMG 9625
11,296
83,820
11,296
83,820
So the 3pt hitch lift lever check chain threads stripped again at the turnbuckle. Anyone try the slider/pin setup? Saw comments on a tractor forum that the L8430 kit would also work on a Kubota B7800.
DE6C13B2 A442 4065 862C B1405057E492
Backwoods
Backwoods
31,859
327,821
Douglasville ga
I have it on both tractors they came factory with that set up. I like it and have had no problems.
7,126
27,010
I have a set of these laying in my shop. I just havent installed them yet. I have to do some pretty major stuff to install them. The original turn buckel setup is a PITA!
Dad has it on his Kubota and it’s sooo much easier. Might have to look at putting it on the old massy I’ve got. Hadn’t really thought about it before. I like it
Backwoods
Backwoods
31,859
327,821
Douglasville ga
It's good to be off for the weekend . Did some bushhogging today try to get things looking good.
20190906 133426
make the picture bigger and you can see some of the local deer
20190906 200511
another fresh cut shot
20190906 200227
had to get a 700 pic while I was at it
20190906 200402
nothing like driving the tractor all day then going for a ride.
11,296
83,820
67C5DA0D 5CF4 4D5C 9E61 A61EE467C1C2
FD95C005 294E 452B B8DA F02B80ACE145
Thinking about getting a tiller for the Kubota 30 hp. Maybe 48 inch given hard soil. Any experience with tillers? Did this smoothing with 4 disc attachment and landscape rake, but took a full day. Wetted soil with P500 and water tank/pump set up.
VaHillbilly
VaHillbilly
NTC immigrant gardner
5,864
51,159
Sw VA
View attachment 154145 View attachment 154145 View attachment 154146 Thinking about getting a tiller for the Kubota 30 hp. Maybe 48 inch given hard soil. Any experience with tillers? Did this smoothing with 4 disc attachment and landscape rake, but took a full day. Wetted soil with P500 and water tank/pump set up.
I've used a 60" tiller putting in food plots and it worked flawlessly! Makes a plow&disk obsolete! If you can do it dry it looks like powder when you get done! You will be very happy with that
