Mopower58
Unburdened by what has been!
Just for the record I do not have the rough country shocks. I did not want the digressive valving. Yes they will be better than stock. Most anything is. But they are fine for the price point and people do like them. I really like the Bandit shocks. Yes different price point and it really is about what your expectations are. I really like their valving profile. Jackyl has them also. Depending on what you can budget the RC will be an improvement over stock and worth the 700 dollars. If you can afford more to me it is a no brainer for much improved valving profile and much higher quality IMO. I have them on both sxs . They are even my choice over the elka I had on previouslyLook into the Rough Country shocks for it. I’ve heard nothing but good things and at a better price point. @Mudwisel has got them
I would order the bandit stage 4 . The others offered are the elka stage one and stage 2. The bandits are IMO just as good in quality and performance at a much better priceI looked up the Bandits and they are affordable for us.
Can I get the package of four for the P1000-5 Deluxe? Seems strange the price isn't much higher than just the 2 shock package.
Start with your settings in the middle.Is it easy to change out the shocks?
I am not the one who does this stuff, my husband would and he is handy, but not a mechanic!
Also, how hard is it to set the dampening on these adjustable shocks? I have adjustable shocks on my mountain bike and hardly every adjust them anymore lol...
Welcome from the once great state of Colorado.Thanks for the welcome!
It looks like the low gear setting is for 5mph and under only which limits its use a bit.
It sounds to me like you were in High Range and should have been in Low Range.I’m not sure if it’s the clutch, transmission or throttle lol. It’s a bit below 10mph around 7 or 8 mph, too fast for low gear, but seems to be too low revs for high gear to hold steady. Shifts gears back and forth, seems to sputter and lunge a bit.
It did seem improved on our last ride at about 10 hours and 75 miles of use. Also, lowering the tires to 16 psi helped immensely, maybe just not getting bounced around so much and seat covers helped sliding around on seat, keeping foot steady.
Yes, easy, each shock has one upper and one lower bolt, all you'll need is a way to jack up the buggy to take the load off the bolts.Is it easy to change out the shocks?
There's low gear and low range, low gear can be used in both high range and low range. (as can all 6 gears and reverse)
Low range is good for speeds from 1 to ~25 mph. High range is good from 1 to ~65 mph.
Since much of your riding is technical, you'll spend that time in low range and still have all 6 gears available but a lower top speed (which you don't care much about).
Not trying to be condescending, I just don't know what you know about the use of Low and High range.
I think the P1K is spec'd at 14/15 pounds of tire pressure, so, at 16 pounds, you're still a bit over. You'll have to experiment with that for a couple of reasons - 1. No beadlock rims, so you can't run 'real low' pressures (risk of debeading). 2. Lots of rocks with lower pressures could cause a pinch flat. This depends entirely on how aggressively you ride - 1. casually will allow lower tire pressures for a better ride. 2. higher speeds will require higher tire pressures to prevent pinch flats. Highly recommend getting a spare tire ASAP if you want to try lower tire pressures. I ran 12 lbs. without beadlocks and that's as low as I was comfortable with as a solo rider (not in a P1K but similar weight machine). Others have run 8 lbs without beadlocks and had no problems, that's completely dependent on your riding style.
I think you misread something, Low Range is good for ~30 mph in 6th gear. Watch your tachometer, it'll stay at a low rpm, even in low range, up to ~30 and you can 'paddle up' anytime you want. If you're going too slow for the next gear, the software won't let you do it so feel free to try it a few times. I'm constantly using the up paddle to short shift and keep the rpm down.Hey thanks for the information! I really appreciate it!
So here is the thing about the 'Low Range"....I looked it up in the owners manual and it said to use it only up to 5mph at consistent speeds?!?!
So yeah, its almost useless for cruising over rough terrain unless your going up very steep and rocky, rutty 4wd type terrain...that's all I've used it for when I read about the 5mph.
What am I missing?
Could someone with a newer P1K confirm this, plz? This sounds insane to meI just went and looked at the owner manual again and it says to use the Low Range when driving at a constant low speed of 5mph or less.
I think that makes it almost useless except for tough 4wd up inclines or when I weed drag with it.
Is this another silly instruction they put in there to cover their buns if something goes wrong?
