P1000 Trail model rear view mirror..
ButchersHook
ButchersHook
167
332
Buying the trail edition, I had figured the rear view mirror was similar to the one I bought in the past...mirror and clamp. Nope the front t cross member actually has a welded braket for the mirror. Which means the factory makes special cages for the trail vs the non trail...which makes no sense.....
115,430
You should compare an LE to a Deluxe and you'll blow your 🤯
This is nothing new unfortunately
NewHere2
NewHere2
Village Idiot In Training
41,748
344,278
High Plains of SD
The Forest and Deluxe have the cage bracket too. Not sure on the EPS.
HondaTech
They all have the bracket, just no mirror for deluxe and eps.
Jankyeye
Jankyeye
827
4,004
Tampa, Fl.
22 Base model here and it has the welded bracket.
115,430
Last one was an LE, one before that was a Deluxe.
then this is not news to you then 🤣
What happened to your other 2?
Do u have the 3rd one yet?
I
ike775
48
116
yerington nevada
Is there a way or bracket to mount the mirror on a deluxe without the welded bracket?
Scrappapotamus
The Scrappapotamus
749
3,964
Midway KY
  3. Talon X
  4. Talon R
  5. Talon R LV
You can mount a rear view mirror that has a tube clamp mount
