O
Anyone have an enclosed trailer worth advertising? Tracks go on in about a month and with the soft cab, I would like to run down the freeway with it enclosed in a trailer.
Thanks!
Thanks!
I have an 8.5x20Anyone have an enclosed trailer worth advertising? Tracks go on in about a month and with the soft cab, I would like to run down the freeway with it enclosed in a trailer.
Thanks!
Yeah and I imagine you can just let air out of tracks like a tire to squeeze it in there
Lowering cage isn’t bad if you’ve got welding knowledge.4-5 in chop pretty easy. Make sure to sleeve it.been doing some research on this lately, there are a few that have have 7 ft ones now but you lose 6inches with the door frame so the its really 6ft 6inches, they have some gooseneck car haulers that are higher, my avalanche cant do a bed mounted hitch though. been thinking about lowering the cage, though i havent looked to see what that would entail either, because the tall ones are also incredibly expensive
BARN DOORS... not a ramp being the key to fitting in a 78” openingthe 7ft one barely fit if he says you can fudge it, might be what I get, I want to get 28 or 30s and whatever minim lift I can to clear them, but that's just, if the op wants tracks would have to find a trailer 7.5 or 8ft tall. I would have the thought the tracks add more than 5-6 inches, they look like maybe another 1ft. I haven't seen any in an enclosed trailer, if you do find one its not going to be cheap
I have a 2015 700-4 with tracks and I was going to cut my roof but I found a very inexpensive fix. I use two 2inch ratchet straps and compress the rear suspension,(5 inches) drive in and release the straps. When I'm ready to exit I compress the suspension and back out. I made special hooks to hook onto the top frame.the ones I was looking at only one trailer even around here with barn doors and 7ft, and he wanted 5500 for 7x14. I got my 6.5 pace 7x14 for 4200. same place has a 7x14 7ft but he wants 5300 too. all the cheaper ones 6ft opening and ramp doors and I'm sure the same affect could be having the front lower or lift the wheels. one of the reasons I liked the pace is leafs can be flipped to raise it and can be overloaded without hurting it too much. that place I listed on Cl is about 5 or 6 hrs away, anybody local is a thousand or 2 more. kinda why i was thinking lower the cage. my rhino fit in the pace it was like 74 with 27s, but once I sat in it and had my stuff in it would clear the door, that was ramp door too. I have a welder I have built a ton of things over the years. the open trailer I'm hauling the pioneer on now I built because they don't make anything thats tall enough to not hit on some of the places I go four wheeling and you can side load three quads.
you have to have skis in front for minnesota trails and wisconsin says factory tracked machines onlyWelcome OleRed! Remember you will need a trailer with the proper door height. I think most enclosed trailers have 5 foot doors. Dad had an enclosed trailer that I wanted to convert to camper/toyhauler but the door was to low.
Do the tracks make it ok to use snowmobile trails up there?
Why not just buy an enclosed and be done with it?My travel cover just showed up if that is any clue on my direction for this year fishing. see how frustrated i get taking that thing on and off all the time. I am leaning toward a trailer with a custom salt guard where it takes the majority of the wind and salt....?
