P1000 Trailer ???
Robobrainiac
Robobrainiac
2,460
8,569
Picking up a new to me Honda 1000-5 pioneer tomorrow. Will a U-Haul auto transport trailer work to bring it home?
Excited for my new toy
If you need a flat trailer check your local tractor supply store, they rent them in some areas.
Robobrainiac
Robobrainiac
2,460
8,569
From what I can see I do think it might work
Screenshot 20211008 164943
howardjg
howardjg
11
46
Thanks for the advice so far....of course U-Haul didn't have the trailer I reserved online so I ended up with this..
Murphy's law I guess
16337324204245288863049730889535
Reactions: Lady01 and ChadD
howardjg
howardjg
11
46
Does anyone know the width of the tires inside to inside and outside to outside? Trying to confirm before I head out tomorrow.
Gabbas
Gabbas
280
700
Humboldt, Iowa
Outside to outside on a stock machine is 63".
Front wheels are 9" wide and rear are 11" wide. I'll let you do the math.
Sent from my Pixel 4a (5G) using Tapatalk
StewB
StewB
668
3,098
I tend to frequent this site so's I don't have to do the math . . . : )
Worse1
Worse1
145
554
Arizona
Congrats on the new rig! If you ever need some LED whips, just let me know. Let the fun begin!
bumperm
bumperm
1,850
6,651
Gardnerville, NV
Trailer worked perfectly better than I expected.... Now the fun begins...
If you can get the front tie down strap attach points lower down, I think it'll be a lot better. The fore and aft frame rails, just aft of the front end, have elongated holes on their underside. Hooks will attach there securely and will put a lot less stress on the front tie downs.
The front bumper is kind of a fake out. Looks strong, (and is doubtless strong enough for being a bumper) but the attach to frame is all at the bottom - so where you show attaching, besides the suboptimal high angle, is cantilevered up there near its weakest point.
Okay! Congrats on the buy!
StewB
StewB
668
3,098
I always tie to the A arms out by the wheels. If you tie to the bumper, especially angled up so steep, each bump in the road bounces your machine straight against the tiedown points. It puts a lot more wear on everything.
If your straps come in at flat angles or tie on below the suspension, the machine bounces without slamming against the strap or tiedowns.
PJon
PJon
766
3,091
Arizona
I should, don't see why not. Make sure you strap it down properly. 👍
Pics or it didn't happen!! 😂
NTC
When you pick up the trailer, don’t let them know you’re hauling a side by side. For some reason they think you’re going to abuse the trailer. I used one of their car hauler trailers to bring mine home.
W
Walterr
21
Orem, UT
Glad it worked out for you! I rented a U-Haul utility trailer to go pick up mine and realized when I got there that the trailer had triangle braces that narrowed the back opening to the point I could not get the machine onto the trailer. Should have gone for a vehicle trailer. My wife drove home with the empty trailer and I drove home the long way on the smallest roads I could find. Took a while, but worked fine. Good thing I was just a few cities over.
Reactions: Lady01
IngoTheBarbarian
IngoTheBarbarian
65
180
US
Just in case anyone else finds this useful...
The U-Haul car hauler works perfect for a 4 seat Talon, too. 900d5a62b51b2d4cbd2172a473d82a33
Reactions: howardjg and Lady01
