P700 Trannny slips
G
Gunrunner
0
Nebraska
When outside temperature gets to about 40 degrees the transmisson slips untill it gets warmed up. Honda 700 pioneer
allgm1
allgm1
1,049
1,484
New Hampshire
sounds about right if your oil level is good as @Hondasxs said. I know I can't just jump in mine and go til its had a while to warm up.
Russ989
Russ989
22,569
146,535
As stated by @Hondasxs, I always make sure the oil level is at the top of the mark on the dip stick. I also start mine and let it idle a minute or two before taking off. Just the nature of the beast with the 700.
Reactions: Deluxe700
TomB985
59
96
I don't have a P700, but this thread has me curious. What exactly happens when you try and drive before warming it up?
Neither my mom's P500 or my P1000 do anything strange when cold, but of course they have completely different transmissions.
Russ989
Russ989
22,569
146,535
Your moms p500 is basically a wet clutch foot shift atv tranny operated with electronic shift solenoid system (no foot needed). The 1000 is a dual clutch tranny with shift solenoids. The 700 is a torque converter tranny, more like a truck or car, the oil has to warm up and expand enough for the torque converter to function properly (operates on a hydraulic basis).
Reactions: Mudwing and swsebek
TomB985
59
96
Yeah, I was aware of the differences with the fluid coupling. What doesn't make sense to me is that automatic transmissions for cars have been using this type of system for decades, and seem to operate fine without warming up. What makes the P700's system different? How does it behave if you try and drive when cold?
tjoreo
tjoreo
1,011
1,929
Southern Idaho
The 700 uses the engine oil to drive the torque converter, vs a car having separate automatic transmission fluid.
Reactions: Russ989 and Mudwing
63,560
I'm no expert. But this is what I think too.
And as for what will happen?
Nothing really.
That's the beauty of the torque converter. But im sure if you do it every time you'll find create a problem.
7,143
27,162
My 700 would not shift properly when I would ,start it up and drive away. I would have to let it run for 30 to 60 seconds first. I live in Central Texas where it doesn't get real cold.
allgm1
allgm1
1,049
1,484
New Hampshire
if I get in mine when its cold without warming it up it does ok in first gear but shifts really slow into second but when it comes time for third gear its like some one pushed the clutch pedal in.I have to let off the gas a little and it will catch again in second gear, then shift to third. My understanding it that the oil isn't flowing (because its cold=thick) into the torque converter fast enough so it can transfer the power. This is a real pain in the neck during the winter,it has to be warmed up even after sitting for a few hours after a ride, one would think it would be warm enough but NOT.
Russ989
Russ989
22,569
146,535
I’ve heard switching to the Honda HP full synthetic oil helps. I spoke with a tech at Honda a few weeks ago that confirmed that oil is compatible with our pioneer 700’s.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I use the Honda Full Synthetic Oil...No Problems...It does help over conventional oil in my opinion.
allgm1
allgm1
1,049
1,484
New Hampshire
I don't see any harm in letting it warm up, after all its not really a bad thing to let the engine warm up before using it. I'll continue with the regular good ol been around forever dino oil and let my rig warm up for a a while, i'm in no hurry to go anywhere anyway.
