transmission
Hound
5
7
Orleans, Ontario, Canada
Good morning everyone,
I have a 2017 pioneer 1000-5 deluxe which for some reason won't change gear. So far my remedy to the problem is to pull out and re-place a 15 amp fuse . My dealer told me they couldn't find the problem , does anyone else had this problem and what was your solution.
Hound from Ontario, Canada
272,137
There have been sporadic cases over the years of loose ground wires on the Pioneer 1000 machines. They have caused all manner of issues and symptoms. There is 2 or 3 ground wires . I have not personally dealt with the issue but have seen dozens of posts with problems that turned out being the culprit and fix. Just use the search feature in upper right for prior posts, I believe a couple had pictures of the locations.
