Does anyone know if it's safe to transport PK vertically?
Google has let me down.
You'd want to make sure your vent lines are run in a way that would support that. I also wouldn't want it sitting on the cage (assuming rear end down) as they aren't overly strong to begin with. Overall this is one of those ideas that I would say might work, but it definitely isn't designed for it.Does anyone know if it's safe to transport PK vertically?
That was a can am though. Those guys are full of bad ideas....starting with buying the can am.Thought I saw a picture of a sxs hanging vertically off the back of a large motor home. Saves on trailer I guess??? Couldn’t tell you anymore than that. Looked hairy as hell to me.
Here is a better idea for a trailer behind a motor home.
They come in several sizes.Swivelwheel-DW58 Tandem Tow Dolly
This hauler/carrier is great for transporting motorcycles, ATV's, Trikes, Can-Ams, Golf Carts, etc. The Swivelwheel DW-58 Tandem Tow can go on Class A,B and C motor homes. This system can carry up to 1,200lbs and flat tow up to 6,000lbs. The Swivelwheel Systems cannot jackknife or sway unlike...www.cruiserlifts.com
I have a converted school bus, it worked great for a dirt bike hauler but not long after we added Sxs to the mix we quit running it. Obviously they won’t fit inside because of height restrictions, plus a pusher is more limited. We did build a rear platform for a quad, that was doable but pita. I absolutely hate trailers especially behind that, going deep into woods 60ft sucked. Just converted a moving van so we could load up inside. Like said though you’ll probably just have to go trailer unless you want to cut out the mid sectionVent lines I considered, I just don't know about the engine and tranny fluids. Batt's are no spill, mount any orientation.
Jacks pretty much nailed it. I'm converting a school bus into an RV and weighing options for trailer or no trailer. Because of limited access to the engine (rear engine, 8.3l Cummins), and frame modifications costing me floor space in the bus, I'm leaning towards trailer regardless. With the trailer, I'm leaning towards the Jeep Grand wagoneer. Or no trailer just taking the ftr1200.
My thoughts exactly except I was thinking about the way a front wheel on a zero turn radius mower goes berserk when on pavement.Ever see the front caster spin crazy on a shopping cart?
Ive pulled a lot of farm equipment with swivel wheels...and they can and do spin till the tire blows if your not paying attention.
One good pot hole and those itty bitty casters will be gone!
For crying out loud a simple double axel steel car trailer and hitch will set you back 2.5 to 3k tops!
You can find nice aluminum ones for another 1 k more!
