I was curious to know if you can use a cigarette lighter style trickle charger to keep the battery full, or do you have to connect directly to the battery? Any harm in using the cig plug hole to accomplish this?
I offer this kit that was originally a custom request just for this. It allows you to re-wire the cigarette lighter to be straight to the battery. preferable, through a fuse box.
This kit lets you change how your ACC "cigarette" socket works. You can directly power the socket or re-route the power to a second battery. You can also wire it directly to a battery for constant power or charging with jump boxes or trickle chargers that utilize this type of plug. SET - The...
