I
Or dating three sisters ... Lucky Bastard!Whit your title, I though you just had Triplets? I was thinking…Poor Bastard!![]()
Very Nice.This is just quick note to the Honda SxS forum and the club store. Me and my brother installed these plug and play light bars yesterday on my machine (middle one) his machine (the gray one) and our dads machine.
These went really smooth no problems installing them. Very happy so far.
Thanks
Looks great.one question . How much risk is there to the staring battery using the plug and play light bar and rear lights?Very Nice.
I see you changed it around to go under the bar. Fits really nice there.
Add link for those intersted. This is becoming one of our top-selling items.
Add-A-Light!, High Beam LED Light Bar for Honda Pioneer 1000.
The simplest way to add a light bar to your Honda Pioneer 1000. ***Attention 2022+ owners*** We now have a light bar bracket that works for the 2022+ units. See images labeled "FAIRLEAD MOUNT". This fairlead mount positions the light bar just above the winch. When you choose this option, it...store.hondasxs.com
Not much.Looks great.one question . How much risk is there to the staring battery using the plug and play light bar and rear lights?
Zero, really. Assuming you have a dual isolated battery setup, it's not like you're drawing a ton of amps off the primary batterty while running your heater, winch and hydraulics (snowplow), lights and radio while plowing. All the latter stuff (and more) is really why one benefits from a dual battery and isolator setup.Looks great.one question . How much risk is there to the staring battery using the plug and play light bar and rear lights?
There are so many possible accessories, you need to be more specific. I can tell you that smaller LED's like pod lights or rear back up lights will draw about an amp each. Not sure what the headlights draw, the LED version will be more efficient, guessing 6 amps on high beam, but I've not measured them. A Boss radio, maybe 3ish, depending on volume . . but a big amp and sub woofer in and it'll draw a lot more when you turn up the gangsta rap. If you install an underseat fan, that'll draw 3 to 4 amps. Most of the smaller things, phone charger, tablet for map, etc. will be less than an amp.Makes sense to me. Does anybody know what the plug and play accessories pull in amps? My winch is wired to my main battery(factory installed) so I know i have that possible issue anyway.
Mine is a Base model my dads and brothers are deluxe models. but after installing the light bar the headlights looked so out of place I changed them out for LEDS. much better. On a side note I have deluxe wheels and LEDS I should have bought a deluxe from the get go. I am happy not to have the color match panels. The black shows no scratches at all.Not much.
if you have the base model halogen head lights, swapping them to led will help free up load to run the light bar if your worried about it.
