P1000 Tusk Terrabite Replacement Question
bmcote
bmcote
54
227
Colchester, CT
Hi all, long time since my last post! Looking to replace my stock tires in the next year with Tusk Terrabites. I do not want any other mods (rims, etc). What size do y'all suggest? Below are my options from amazon...
1720704617504
Jankyeye
Jankyeye
883
4,196
Tampa, Fl.
If you don't want new rims/spacers, the first option wont work well since the factory rims are different widths.
option 2, The 29" will likely work, may rub slightly at full lock.
3rd option is for 12" wheels, assume you have 14" wheels?
last option are factory size so will work for sure.
bmcote
bmcote
54
227
Colchester, CT
exactly what i was looking for. i'll plan on getting the 27x9-14/27x11-14 (last option). thank you!
Scoop
Scoop
5,438
21,385
  3. Talon R LV
Stock P1K with stock 14" rims? The 28-10x14 all the way around will work, @Jankyeye, even with different width rims.
540RA
540RA
Not So Well-Known Member
281
2,747
  1. 1000 6 Crew
28x10-14 on mine as well. 1" RB3 spacers in back line everything up perfectly.
Reactions: Backwoods
540RA
540RA
281
2,747
  1. 1000 6 Crew
Do you have any pictures of 28x10 on factory wheels? I’m trying to decide to go same size or offset.
No…sorry...forgot to mention that they're mounted on aftermarket wheels. OP wants to stick with the stock wheels, and i didn't take that into account. Oops. My screw up. 😬
