P1000 Under hood wire management
Hondoman
Hondoman
727
1,697
Texas
I've got alot going on under my hood. The following are under there:
Two batteries
Isolator
Winch, light bar & key on relays (for fuse box)
100a disconnect
Key on fuse box
Always on fuse box
Negative & key on positive buss bars
60a fuse holder for amplifiers
Crap ton of wiring
Looking for pictures/ideas for wire management under there. Seems I'm never finished, always adding or cleaning up. I for sure need to shorten some wire lengths where possible.
This is what it currently looks like:
20180903 132550
rlutech
rlutech
261
359
I made a plate to mount all of the electrical components in one spot. I made kind of a harness that wraps to the other side of the compartment (near the starter solenoid where I’m grabbing power for a few things). If I unbolt the plate, I can lay it and all of the wiring to the side out of the way.
4902974C 95DD 45F3 8FE9 122E389FD6FB
Muhkan51
Muhkan51
Love this thing!
32
41
Louisiana
WoW!
Reactions: sharp and BWAF
RockRain
RockRain
48
101
UT
That looks like some nice work! I see that you used the same Bussman fuse/relay box I did.
Thanks! It is a pretty cool they have this stuff available. Nice to have a sealed unit for what these things get used for.
RockRain
RockRain
48
101
UT
DIY - Build and install a Bussmann RTMR Fuse/Relay Block
I finally found the tutorial that I followed to do the majority of the bussmann. I wanted to give this guy credit for the amount of work that it took to write up something and help others out. It is packed with resources and how to's. I don't know what happened to the other blog site of his that I had bookmarked but it doesn't work anymore.
renosxs
renosxs
19
32
reno, nv
excellent source of information, wish I had this before starting. Good news is that I used items on the link. Thanks for sharing.
Reactions: BWAF
WhitJo
WhitJo
47
168
Mtns of East TN
My dual battery install has been completed for awhile...
I haven't had time to add any accessories except the turn signal kit...but it's ready
Here's a short clip of the Tru isolator in action...works perfectly
Reactions: BWAF and sharp
