Talon Using the stock rear wheels on the front?
jonathannook
jonathannook
11
Quartzsite AZ
Wondering if I can use the stock Talon rear wheels and tires on the front instead? I want to buy wider beadlocked wheels & tires for the rear that can be aired down to be better in sand, without going to paddles.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
It should work. It will widen you up about 3 inches in the front to about 71.5"
If you put 4+4 on the rear with stock rear tires, you will end up right around 71.2 in the rear.
Reactions: jonathannook
