P1000m5 Using winch LE would die when trying to shift
Elkhunter
Elkhunter
345
453
Minnesota
I was cutting and hauling firewood when I got a tree hung up. So I decided to hook the winch up and drag it down. After I got the tree down I went to put the buggy in gear and it would die. I thought okay I drained the battery some so it let it run a while and tried to move it again. The park indicator was flashing a dash- tried to put it in gear and it still dies. It would fire right up in park or neutral. I was a quite a ways in the woods and was wondering what my next move would be. Decided to try disconnecting the battery and hooking it back up and it worked fine. Has anyone have this happen before? Do I need another battery? I also have been using the winch to lift my plow up and down. No other accessories.
Neohio
Neohio
Beast of the East
17,948
86,626
Painesville Ohio
If you get in the situation again, and I hope you do not, please whip your phone out and video the dash. It will usually throw some codes to help with diagnosis. Do not turn the key off until you have roughly one minute of video. That should be enough to record most codes.
Reactions: CID
Hawk53
Hawk53
485
622
Alberta Canada
Havent had any issues related to this type of thing but it appears to be very common with high draw on the battery. One big problem with using electronics.
Hawk53
Hawk53
485
622
Alberta Canada
Maybe a 4D battery would help those that are looking for the severe situations and lots of winching
208,730
I was told to go to secondary battery with isolator for all accessories Seems to work very well so far. I installed two volt meters to monitor voltage on both batteries, like I was told to do and my primary battery stays the same voltage all the time, even running accessories. There are some great threads here for all this stuff!
Elkhunter
Elkhunter
345
453
Minnesota
I suppose I’ll have to go to dual battery’s. I know a lot of pioneer 1000 people have gone this route.
Just to bad you have to add another battery on a new machine in order to use a winch!
Dasmoeturhead
I've got a question. Do the Honda ATV's (4 Wheelers) have a problem with this same battery problem when they use their winch? Never owned one, and I don't really read anything about them. It seems a lot of them have a winch, and I bet the battery is even smaller than a pioneer's battery. I can also imagine trying to shoehorn a second battery in a ATV would be near impossible.
I don't have a dual battery setup yet, and I plow a little bit. Never had a problem yet, but like I said I don't plow that much
Maybe an hour at a time.
That second battery spot on the pioneer is awful suspicious. Like Honda knew something. Maybe they should let customers know they need a 2nd battery if their going to plow, or load up with lots of electronic stuff. IDK.
Sounds like you need a second battery... when you were winching did you put it in neutral and run the rpms up or just let it idle?
Elkhunter
Elkhunter
345
453
Minnesota
No,I left it in park but Reved the engine slightly.
Reactions: JTW
Neohio
Neohio
Beast of the East
17,948
86,626
Painesville Ohio
The transmission and the heavy inclusion of electronic controls is what makes us run a second battery. The discharge of the battery while winching really messes with the transmission and creates problems as the OP noticed.
1BadDart
1BadDart
1,437
13,308
W. KY
It looks like there is a market for a high output stator for these machines if someone would build it.
Reactions: JTW
Someguy
181
179
Krakow Wi.
I was going to put a winch, and plow on mine, I got a quote from the dealer, they recommend installing a second battery. He said because of the draw of the winch, it can cause voltage to drop to much and cause problems with elctronics. I used his advice and installed second battery, and isolater that others used on here my self, saved about $400. Works fine. Hope that helps.
Elkhunter
Elkhunter
345
453
Minnesota
Bit the bullet and ordered a isolator and a battery. Thanks Honda for nickel and dimeing me!
Reactions: JTW
208,730
There's some threads here that will tell you the make and model numbers you will need for all the equipment. I think I have $ 300 to $ 400 in my battery, fuse panel, isolator, toggle switches, volt meters, toggle switch panel and wiring.
Are the wires in this kit long enough True UTV-SBI-15CM UTV Dual Battery Connect & Monitor Kit | TrueAm Dual Battery Isolator System
I read the lengths and it looks good.
These things are good at that... and honestly. Honda has perfected that across their sxs lines
Elkhunter
Elkhunter
345
453
Minnesota
That I did, searched the forums and found what a lot of guy were using. I ordered an Odyssey Pc925,True UTV sbi15cm isolator kit and the L terminal kit for the Odyssey. Thanks to this forum for all the informative posts!
Reactions: JTW
208,730
Your way ahead by using the info.
Reactions: JTW
