P1000m5 Using winch LE would die when trying to shift
That I did, searched the forums and found what a lot of guy were using. I ordered an Odyssey Pc925,True UTV sbi15cm isolator kit and the L terminal kit for the Odyssey. Thanks to this forum for all the informative posts!
Might I suggest an accessory switch in there so you don’t keep continuous power to the future accessories. Also a fuse block.
212,771
I talked to the owner of Tru isolators, he asked what battery I would be using and I told him the Odyssey Pc925 and he said that was great because that the battery they designed there isolator to wok the best with???????
212,771
I agree.
Elkhunter
Elkhunter
345
453
Minnesota
That will be in the future if I get any accessories. The only accessory I have is the winch.
Reactions: JTW
Elkhunter
Elkhunter
345
453
Minnesota
That’s good to know! Thanks
Lol.. You’d just as well start figuring on how it will all go together..
212,771
Gota get whips! I thought they were the stupidest thing I ever saw, until I went on a night ride with folks that have them.
Dgrinde
Dgrinde
14
16
N Idaho
I was going to put a winch, and plow on mine, I got a quote from the dealer, they recommend installing a second battery. He said because of the draw of the winch, it can cause voltage to drop to much and cause problems with elctronics. I used his advice and installed second battery, and isolater that others used on here my self, saved about $400. Works fine. Hope that helps.
Yes my clutch slips under load running winch.
Y
Yukon Off Road Repair
Macon Georgia
PROBLEM SOLVED!!! BAD VEHICLE SYSTEM GROUND. That's right I said it. Working with a brand new 2024 Honda Pioneer 700-4 Forest (so you know that comes with the warn 4500 winch) I began having problems with my engine shutting off. This began after I got my home made roof, light bar and cab lights all installed. But one more thing to add was vertical channel iron to the front bumper and horizontal channel iron over the roll bars which I installed roller fairleads for winching backwards or pulling a big deer into the bed. Hey, I'm well past 60 so I look for ways to make my life easier. Back to the winch... so every time I was turning on the winch, it didn't matter forward or backwards it would cut the engine off. Contemplating taking it back to the dealer wasn't an option for me because I live in middle Georgia and I drove to Jackson Tennessee to buy this one, (a fourteen hour round trip) but worth it. So, after reading all the wonderful comments here and in Honda forums I was about ready to go for the second battery installation option. I have my own shop and decided to troubleshoot myself. I had a pair of jumper cables so I got my boat battery out and set it up on a stool in front in my shop. With the positive power cable disconnected from the winch solenoid and using the jumper cables from the boat battery I surprised that I was getting the same result still. So why not jump the negative (ground) side and see what happens? Without even using the spare battery, I used my jumper cables to jump from the Pioneer battery negative to another clean ground point under the seat. BINGO!!! We have winch turning and Pioneer still running without so much as a sniffle. Well the obvious at this point is to remove the jumper cables and check my vehicles grounding points. I didn't look real deep but I did find two right off. One grounding the front of the engine and one grounding the frame up near and under the fuse box. They were both factory tight as well as the battery terminal itself. And I'm still having the same problem unless I have jumper cables assisting the ground sequence. Seeing where I need to go now... I just so happened to have a spare # 6 black cable with eyes already crimped on each end in my box of old winch parts. Snugged it down to the negative battery post and attached the other end to where the oil spout attaches to the frame under the drivers seat. Wala, I have had no more problems after adding this extra grounding cable. I cannot explain why the factory cables are not enough to do the job but forget about extra batteries and the Dual Battery Connect & Monitor Kit which together might cost you $3-$400. Hope this helps the next fella.
Hello_Darkness
Hello_Darkness
681
2,761
Just to the right of nowhere
Check the ground under the passenger side front fender, if it's loose the unit will idle but die when trying to drive it
Reactions: CID
JenElio
JenElio
82,831
718,068
Loxahatchee, florida
Wow........ that's gotta be the longest first post anyone's ever made 😂😂😂
Welcome to the club from South Florida 👍
Glad you found your issue, now start an intro thread and post some pics of your buggy 🤘
GovtMule
GovtMule
22,159
189,153
Tennessee
What about longest duration between posts too?
Hawk53
Hawk53
485
625
Alberta Canada
Are you going to persue and find the reason the factory negative cable isnt doing the job?
P1K5Dave
P1K5Dave
2,335
8,711
Petoskey, MI
I wonder how often guys could diagnose a ground problem by running a cable from the battery (-) to the frame?
It would seem to only work once in a while depending on where ground is poor, but maybe more often than I'd think.
G
GolfCart
149
424
NH
I've done it several times to troubleshoot a bad ground. Also sometimes use a voltmeter to measure voltage drop from the battery negative terminal to the frame and look for a voltage drop that wouldn't be there with a good ground.
Reactions: P1K5Dave
