![JCart](/data/avatars/m/0/959.jpg?1571643654)
JCart
Thought I'd try an install of the Atwood inline 3" e fan along with some 3" aluminum ducting to combat the exhaust heat from under seat area. Initial notion came from reviewing posts in the PK1 forums. Put a manual switch in the dash and linked the power to auxilliary underhood battery. This V1 is not fancy but rather basic wanna try it out first then modify it if it works. E draw with the fan is I think 3 amps or so and it moves 145 Cfm. Have it set up that it pulls air from under driver's side front corner of seat then discharges inline with exhaust system. When I turn the fan on it discharges a significant flow out from under the seat to just infront of driver's rear wheel. Hopefully will carry steam away too. Pix are in my sig link in the under seat folder.
Cheers j
Cheers j
