![L2R](/data/avatars/m/16/16318.jpg?1588208111)
L2R
Understanding women Vol. 1
Once again a very easy mod but I never found any information on what to buy so here it is and a quick run down of where to easily find the hoses and suggestions on where to extend them.
Time and difficulty level: 1 beer at most
Tools:
cutters for the rubber hose
screwdriver and bit (mine was 7/32)
black electrical tape
black zip ties
Supplies:
5/32 rubber hose (at least 12' to do both and reach the roof line)
small clamps
5/32 barbs (optional - can use old barbs if you can extract without damaging them)
![Clamps barbs Clamps barbs](https://hondasxs.com/data/attachments/177/177692-c52deca46fda0830cd2c7516fa79d12c.jpg)
These came from Advance Auto
Looking between the front, driver side tire and front bumper, you can see the hose going straight up over the differential.
![Front diff Front diff](https://hondasxs.com/data/attachments/177/177693-b4d021b143236f456467e99b82d3fdf7.jpg)
It is only about 20 inches long and plugs into the cross tubing of the frame just under the hood.
You can reuse the barb if you get pull it out without damaging it or use a new one.
I routed this from the differential towards the passenger side and ran it up the side, windshield tube and tucked it out of sight just under my roof.
I didn't have any filters handy so went old school and plugged the end of the hose with a #10 screw and a small clamp. I then cut the hose just below to create a vent. I covered the clamp and screw with electrical tape just to black it all out. I tucked this under the roof but it should keep water out I take it off for some reason.
![Vent tip Vent tip](https://hondasxs.com/data/attachments/177/177696-5e03f2cc4ab592144eaee77cb47856a6.jpg)
Between the driver's side rear tire and muffler, you can again find the vent line
![Rear close up view Rear close up view](https://hondasxs.com/data/attachments/177/177694-d8c8fe3d3df0c1851fa6ee9b2e69f77c.jpg)
I routed this straight up to the nearest frame tube, over to the passenger side, back corner, and then up to the roof.
![Bugs Bugs](https://hondasxs.com/data/attachments/177/177703-4da0306f6f6e776367f280f9758b263a.jpg)
Tools:
black zip ties
Supplies:
small clamps
