P500 vid of short ride down to the lake
Nice video. I notice you shift back and forth between 2 and 4 wheel drive on the fly!! That doesn't cause damage as the warning label seems to indicate?? Also, is that a four position rocker switch assembly on the dash?
Haha, glad your passenger had a helmet. That limb popped him pretty good.
Reactions: jak9922
sthomp54
sthomp54
375
Looks like an awesome place to ride, where is it? Thanks for the video.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
big lake down the road from my house that only the half way point but to many down trees now ill have spring clean up to do lol
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
yes I change 2-4-2 on the fly under no throttle and only in L-2 gear and those are 3 rockers and 1 usb charger on my dash
Shadesmn
Shadesmn
505
959
Ramsey, MN
How do you have those switches mounted? Can you post a closer pic?
Amazon.com: Rugged Ridge 17235.20 Black Rocker Switch Housing Kit: Automotive
then trace out on your dash carefully cut and pop in lol easy peezy just remember cut small first then trim u can always take more off but cant put it back
Exactly, use a Dremel not a Skil saw right? what's the difference between the cut out and what the housing frame covers, an 1/8 th. inch??? Say, just checked out your link, it shows four single box housings, you didn't use a single quad box?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
I just trace it out then cut inside the lines
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
On that link i sent u snap the switch brackets however many u want 2-3-4 once they are together place the back of the bracket up against your dash abd trace around the outside with a sharpie then gut it out with a dremel once done and its nice and tight push the bracket in it has little friction clips built in that hold it in place but u can always add a little silicon for added insurance
Thank you!
