P1000 Viper V2 winch install help
Dan AZ
Dan AZ
SanTan Valley, AZ
Installing the new V2 Viper winch. It’s all going well except for the remote control box. There’s 4 wires coming out of it,
Red=power
Black=ground
White=? Has a piggyback spade connecter
Yellow=? Has a piggyback spade connector
Thanks
6C775229 9AD8 40D7 8825 3D974EB73079 07BB94A9 81CF 402F 9441 0F76EF584E3D
115,818
Didnt have destructions?
ill have to check where mine is
Reactions: Lady01 and ChadD
bumperm
bumperm
1,906
6,788
Gardnerville, NV
The red and black are for power + & -. The white and yellow are for "reversing", they would typically go to a manual panel switch (DPDT wired for reversing), or a wireless remote control etc. The reason they have a piggyback connection is so you can conveniently add additional winch controls.
115,818
@Dan AZ found this…
might have different wires but u get the gist. Found it on Amazon.
E49B48AE 4D5B 4F1F 9D9B C3DD4354DDAE
Reactions: Lady01 and bumperm
Soaz1000
Soaz1000
167
915
Soaz
Yours is different than mine.you can find the wiring diagram at the above link
Reactions: Lady01
bumperm
bumperm
1,906
6,788
Gardnerville, NV
On the previous diagram Remington posted, the blue wire on the wireless remote (not shown connected), is the wireless receiver antenna. It's a good idea to add a switch in the red power wire to the wireless receiver. This is to disable the receiver when not in use, and prevents any spurious radio frequency interference from running the winch uncommanded, and potentially doing damage
Dan AZ
Dan AZ
SanTan Valley, AZ
Got it all installed. Thanks for the assist. Only glitch is the remote works backwards, I’m sure its operator/installer error. Spent a lot of time cutting cables to length, but it turned out clean.
BD638C2A 62D7 407E 82BC 3F1F51EC4EE5 5A93AACF 92CD 4375 9509 1D5ECF7B6241 FBEEC333 0098 4C23 93B4 1558155A6635 4F658FFE A805 4746 BFD1 7F3F1681814E 5F7FC516 326F 485F BD12 20CD8F7CCAC9 88916252 575C 46CD 81FB 8D0692F4C092
67,170
I installed my V2, but I didn't even look at the instructions.
Here is the wireless instructions.
If in/out is backwards. Just flip the yellow and white.
Or green and black if the rocker switch is backwards. 84d7a6303f2e104ce1337f36bcf2979d
67,170
Also worth noting.
No wireless remote replacements are available. So buy a lanyard for it and keep up with it.
Dan AZ
Dan AZ
SanTan Valley, AZ
Update. I contacted MotoAlliance about the free spool difficulty of the V2 winch. Here’s their response.
We are aware of the free spool problem and we have parts to fix them en-route. Once we get them we will send out a fixed V2 winch out to you.
It’s always something.
K
Kmeyer1980
10
Ocala, FL
  1. Looking to buy
View attachment 311370 View attachment 311371 View attachment 311372 View attachment 311373 View attachment 311374 View attachment 311375
Hey Dan, I installed mine yesterday and noticed the same that the remote was opposite the rocker……curious if your cable is winding under or over the spool. I did the upside down install. Mine is going under so I think I need to switch rocker wires and remote wires are right. Thanks
Dan AZ
Dan AZ
SanTan Valley, AZ
My cable is going under, but the winch installs upside down, sooooooo, I guess the cable is on top?. Switching the white and yellow solved the problem. Although I'm going to have to remove it to put in a winch with a fixed free spool upgrade when they get the parts.
