P1000 Warn Axon winch fit on Tough Country Bumper?
walexa07
walexa07
396
380
Louisiana
Anyone know if the Warn Axon 55 will fit on a Tough Country Bumper?
Thanks,
Waylan
Fro
Fro
181
656
Ardmore
I have a Warn Axon 45s on mine. You could look at Warns site and see if the footprint is the same.
walexa07
walexa07
396
380
Louisiana
Thanks for the reply. Can you post a photo? I have looked, and the footprint is the same with the Axon 45s as is the 55s. It's the proximity to the cross bar that my light bar is mounted to that concerns me. It looks like it would be a real tight fit.........
Waylan
Fro
Fro
181
656
Ardmore
Not sure why they came out backwards but here you go.
C9B991A4 33DD 4F6E B1D3 29C3B068BCC4
D7DF31F4 B9C7 490B 807B 4E59A8D8A963
13ECC4DB D371 4534 8436 51250FDF82B0
walexa07
walexa07
396
380
Louisiana
Fro, thanks for the pics!
Haldog77, They are an AWESOME bumper. We had the throttle pedal stick on ours and hit a 6" pine at probably 10-15MPH and it didn't do any damage to the bumper. The bumper hit the tree about 6" from the right end.
Waylan
TripleB
TripleB
11,988
101,952
Caryville, Tennessee
Waylan
What caused it to stick?
walexa07
walexa07
396
380
Louisiana
We had just crossed a puddle that was deeper than normal and then I floored it going up a short steep hill. As we got to the top of the hill and I let off the throttle, it just kept going and there was nowhere to go but into trees. Read up on the pivot point that freezes up and spray it with some lube and work the throttle full range with the machine off before you run it each time (to test if it is sticky). Then take it in as soon as you can. Our accident could have been really bad, but we just ended up with a damaged machine (took out the front right a-arms and tie rod) and my wife with a couple bruised knees. Honda warrantied the replacement of the front frame clip and my wife was ok in a couple weeks.
Waylan
walexa07
walexa07
396
380
Louisiana
Thanks for sharing.
I also spoke with Tough Country yesterday and they said it should fit.
Waylan
walexa07
walexa07
396
380
Louisiana
Update - installed the Axon 55-S. It fits but is very tight. I wish the cross tube that the light bar mounts on was 1/4" higher. Other than that, it looks great.
Waylan
Reactions: Haldog77
Pilotadam
Pilotadam
326
735
Pell City, Alabama
FYI you might want to reinforce the tabs the mount the TC bumper to the upper mounts of the Pioneer. In another thread JTW mentioned his bending and I checked mine and they are also slightly bent after so pretty heavy winching.
Haldog77
Haldog77
NTC's Mafia Enforcer
32,119
293,833
Bossier City, Louisiana
Next time you have the bumper off, could you or JTW snap a pic of the tabs that need to be reinforced? I am planning on purchasing a Tough Country bumper or building one very similar. Thanks
walexa07
walexa07
396
380
Louisiana
Same here - would love to see where the reinforcement needs to be. I've not noticed anything so far.
Waylan
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Here is a picture of my TC bumper. I haven't had a chance to take it off and fix it. I notice something looked different on my bumper gap but didn't find the bent tab till JTW said something about it.
I love the TC bumper. The protection and easy of winch access but there mounting to the Pioneer is a little lacking for a winch mount/ pull point.
The picture is my top right mount point.60c51a0489b9ddc1972c575aff2d31c7
Reactions: Haldog77
