Water in the gas
  • Thread starter Deleted member 3748
  • Start date
Deleted member 3748
Got my boat out after sitting all winter and for the second year in a row it has water in the gas tank. I'm probably going to end up draining it, but that's a lot of gas and I don't want to. I did some YouTube research and found a guy who did a pretty good comparison of removal products, Heet, SeaFoam, and isopropyl alcohol. To my surprise. the SeaFoam didn't do very well though he does really like SeaFoam for other things. I thought I'd pass this on since some of us here (including me) use a lot of SeaFoam.
Deleted member 3748
I'm tempted but if I try the alcohol I'm going to find the 99% stuff.
Deleted member 3748
I put a bottle of SeaFoam in my boat's gas tank last fall and another bottle on Saturday before I knew the water was in there. I'm going to keep using SeaFoam in my gas because it's the only product where I actually noticed a difference.
Deleted member 3748
It has a water separator from the factory but it's not nearly as big as that one. I wonder how long it would take to run 30 gallons through there? Thanks for the tip @uconn411
ByronM
ByronM
174
348
St Charles, Il
The old fashion way was to filter the gas though a chamois, a real one not fake, seems like it might ruin the chamois but I guess you could save it for filtering you gas year after year.
Deleted member 3748
I bought some alcohol today and I'll try it and watch it not work. :D I think I'm going to add the separator @uconn411 posted. That looks like the best way to continually remove water.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Yeah, I use Stabil too. My two cycle can always has it mixed in. Some say it does more harm than good but I've never had a problem with it.
Me either. My lawn equipment starts up every spring like new. 4wheeler starts easier in very cold weather too. Good stuff.
Deleted member 3748
I drain the gas out of all my small engines when I stop using them for the season or any length of time over a few weeks.
I also use Stabil.
160,066
I have it in an old generator that I run once a year, unless we have a power outage, and it always fires up. Also have a cheap weed whacker that I figured I would've had to replace by now but it just keeps firing up every spring. Stuff works for me too. ;)
