P500 Ways to reduce in-cab NOISE?
Hondablaster
Bayfield WI
Got a 2017 Honda P500 and would love to enjoy with the kids which I can do about the same as watching tv with them, not much talking as we are listening, but in the P500 it's because the machine is too damn loud to even scream over.
Does anyone have some success stories with soundproofing, an intercom system, mufflers, et cetera?
I just want to be able to chat a little while moving.
Thanks to all who read.
906UP
906UP
14,954
142,097
da Yoop
@trigger sells a rubber shield/mat that goes between the seats & the plastic, it helps but they are still noisy lil fkrs. Putting a roof & windshield on it only makes it worse.
NTC/TAP Transition Member
11,846
90,179
2nd the rubber trigger shield, for reduction of cab noise, heat and steam after water holes. Custom cut for the P500.
snakeriver
272
596
Clarkston Wa
I have a Trigger shield and it works great. I also work where I have access to Ballistic sound deadening that is used in stereo installations, this was also a big help. I would not recommend the ballistic due to the cost, I get it for nothing.
Reactions: J80 and trigger
I second the trigger shield and have also thought about putting an acoustic tile on the inside of the roof.
Spray on insulation painted with RhinoLiner after its dry...🤔
Reactions: J80
Heat shield / sound deaden-er behind and below the seat ,
sof tusk back window roof . Mine is pretty darn quiet with this stuff .
That’s what I’ve got under my TS and a acid/fuel proof liner beneath it...
Reactions: J80
