Welding on machine
Bighat
Bighat
887
3,795
Gallipolis Ohio
I'm getting ready to have some welding done and some it will have to be when the metal piece is attached to the frame of the machine. I plan of disconnecting the battery before welding. Question is, is this all I need to do to be make sure I dont' damage any electrical components?
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
That should be all you need to do depending on where on the buggy you are welding.
If you are welding close to any electronic components try and use a shield of some sort at a damp rag to cover them.
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
Make sure you have a clean welding surface and a clean grounding surface as near the welded area as possible. Disconnect the battery. I have welded on my machine from front to back without issue
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
Why do you have to disconnect the battery?
I disconnect the battery to prevent the power transmission from the weld to go through the electrical system. Yes, electricity generally takes the path of least resistance but if you have a poor connection it may travel through the entire chassis. For instance, if you accidentally grounded the rock slider but welded on the frame, the power transmission could go through anything connected to the frame and rock slider. Ideally, you wouldn't do this but if you remove the circuit through the battery you are less likely to use any power source as a ground to back feed the battery or the electrical system components. In general you are limiting the path of travel for the current applied to the chassis in the welding process.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I've welded a bunch with all hooked up in a swamp with no problem but always a good idea to unhook battery and ecu connections.
