P1000 What batteries are suitable for a second battery?
JiminAZ
JiminAZ
101
184
Phoenix, AZ
So I'm going down the rabbit hole with winch and lights and stuff and want to add a second battery/isolator to my 2019 1000-5 deluxe.
My question is what specific model batteries are candidates for filling that role? I see a lot of folks using the Odyssey PC925 which is a pricey little bugger. Maybe there's a good performance/longevity reason for picking the PC925. I did notice that it was an AGM battery so can be oriented on its side, no liquid.
Any other candidates that might save me a C-note and still get the job done?
A list of models that will work would be a nice resource.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I got 14 months out of my first one of these. Just bought a second one. At a 3rd of the price of the odyssey i figure its still worth it. I think this one will last longer since im using a battery tender now
Mighty Max Battery ML26-12 12V... https://www.amazon.com/dp/B00MHNMJWK?tag=sxsweb24-20
Reactions: Landman
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Just as a note I had my Odyssey Battery in my Kawaski Teryx for 8 years with out a problem. Still running good when I sold the machine (Note I only had the one battery to run the machine, lights, stero, winch). This time around I went with a full size Optium Blue top under the seat. Not much more than the Odyssey but a lot more Amp Hrs.
Reactions: JTW
In hindsight, that’s probably the route I would go.
Kilo427
Kilo427
1,543
6,439
Just make sure you mount it well, as much as you tip over don’t it flopping around down there!
Reactions: JTW and Landman
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I used a Aluminum machine plate I found on ebay for $50 and clamped a steel plate between the plastic floor and the roll bar. Then through bolted the battery mount plate. Seems very sturdy. Then ran 2 gauge cable to under the hood. 73aeefcd1174ff79d5d058c1dae09ea4
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I went with a Yuasa YTX20HL-BS because I had an extra one sitting around and wanted a little more size then the stock 1000 battery. It is 310 cc and I used the Blue Sea Mini add a battery kit, that comes with a charge relay and a battery switch to combine the 2 batteries together if needed. I had trouble starting my old 700 in the cold weather, so I thought it couldn't hurt to have the ability to combine the batteries easily for my new 1000. The battery fits in the slot but is a little taller but narrower then the mighty max everyone is using.
E
Emmer75
20
7
I order a second stock battery and dropped it into the space under the hood. That way if primary battery room a crap I had exact replacement if something happened on the trail.
Reactions: Delton
Dirtstiffs-1000
Dirtstiffs-1000
1,566
5,708
hondasxs.com
Search is your friend.
Most all your inquiries have been discussed before.
Thanks
Kilo427
Kilo427
1,543
6,439
What?? You’re like a f***ing weeble wobble...
Well that’s true it’s also why I don’t have a battery mounted in that location!
Reactions: Mudwing and JTW
JiminAZ
JiminAZ
101
184
Phoenix, AZ
Thanks to all for your input.
Decided to go with the XS Power D925 after reading Bradley-Thornton's thread. Bought the install kit with True isolator here on Honda SxS with my Black Friday discount. Should all result in a clean install.
I thought long and hard about a fullsize under the seat but decided to pass on that, because I want to store my recovery gear there. I do not have many other high amperage accessories (just lights and even those only draw a few amps at a time), and don't plan to add a thumpin' stereo because, well, I don't want one. So the only time the battery will really get a challenge is when I'm winching (208 amps max) and either the D925 or the PC925 will get 'er done.
I also bought the stupidly overpriced side and top terminal adaptors, because I have a thing about neatness under the hood.
Again I really appreciate all of your insights as you got me thinking about the right things for my installation.
Bradley-Thornton
Bradley-Thornton
684
1,648
Hattiesburg MS
You go to admit those terminals are nice lol. They look and work even better in person.
