P1000 What did you use to secure the 2nd battery
Spoof0ne
42
55
New Hampshire
hey guys. I am gathering my parts list for the 2nd battery install for my winch and have everything ready for when I finally get the 2016 1000-5 from the dealer and I haven’t noticed on the dual battery install posts what was used to secure the 2nd battery.
How did you secure it? Part links are appreciated
Thanks
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
I put foam top and bottom on mine machine to round studs drilled and tapped them top and bottom and made a strap to go over the top and bolted it to the bottom of the plastic I had room because u put another factory battery in there
Thanks
0267fc07944d6d19cea0e0a668a941abF5b8c530eab1ef4bbd6a1852ad6880066db08a1513014665990c514df0148980
Reactions: Spoof0ne
67,044
Heavy duty zip ties
Reactions: BWAF
WhitJo
WhitJo
47
168
Mtns of East TN
threaded some 3/16" stainless rod 10-32 and bent a 90º at the end....
IMG 2587
drilled into the plastic on each side at the bend...where it was the strongest
IMG 2589
made a 1/8" aluminum strap and used stainless wing nuts
IMG 2595
SuperDutyJohn
SuperDutyJohn
254
436
Vero Beach, FL
I bought the rubber mat that goes in a tool box to keep tools from sliding and wrapped the bottom 1/3 of the battery and tapped it to stay in place while I dropped it back in the hole. it was very tight and just hit the bottom. I'm going to have a hell of a time when I have to take it out.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Spoof0ne
42
55
New Hampshire
So I have finally had time to work on the winch and add this 2nd battery.
Thanks to everyone for the suggestions. Here’s what I ultimately did:
Dremelled 2 slits in the bottom of the tray to pass a strap thru a lashing strap
2x Lashing Straps with Buckle... https://www.amazon.com/dp/B07G9488FD?tag=sxsweb24-20
Then I added self adhesive foam padding to make up the small gap so the battery fits snuggly. Foam Padding, Self Stick Adhesive... https://www.amazon.com/dp/B06ZY83SZJ?tag=sxsweb24-20
05B422F7 450D 40BB AD98 1BCBBD2653E1 80BD42E0 591F 480E A77B D280D373F864 64E380EB FDCC 46FB AC36 0F6D035B7C16 6FE9B5F2 0AAD 4FE4 9367 DA7BB48340A6
Reactions: trigger and JTW
Choped5er
Choped5er
182
279
Union
I just drilled 4 holes through plastic and put 2 big a** zip ties around it lol was meant to be a quick solution so I could go ride that night, has been like that almsot 2 years lol
Reactions: TripleB and JTW
RedFred1
RedFred1
301
619
North Carolina
Not one damn thing... just a thin white packing foam wrap around the battery.
The wires hold it in place... even when my daughter rolled it... the battery did not move.
FredD
Reactions: TripleB
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Hose clamp. Got the idea from someone on here. I put some foam strips on bottom. Cut two slits in bottom of battery case. Got a 32” clamp I believe and cut to size. Nothing fancy. But easy fix.
Reactions: TripleB
View attachment 117471 View attachment 117472 View attachment 117473 View attachment 117474
That’s basically what I did but I cut my slit above the crossmeber so the strap wraps around it too.
Reactions: TripleB
Pmed489
Pmed489
119
137
Foam inserts from a pelican case on side and bottom No top strap. Don't plan on rolling it over. Knock on Wood.
