P700 what do you guys with 28" tires carry as spare?
swsebek
swsebek
2,854
5,832
pa
You guys that run 28 inch tires....what rim do you use for a spare? I have a set of brand new 25 stocks but I don't think I can use them and if I get a 28 mounted up on a spare rim do I want to use the front rim or is there a different off set to use....It will be just to get me back to truck for repairs.....Even if you don't have 28's whats the right choice.
Tramguage1
Tramguage1
Texan
7,347
29,399
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have 14x27's, bought 2- 27x12's to mount on stock rims. I figure if i ruin a tire on the trail i would put a stock rim in its place untill got back to truck. Then put the matching stock wheel to match the other.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
The front stock rim will fit on the rear but the stock rear rim doesn't fit on the front unless you're running wheel spacers.
Best choice is a 28" tire on a stock front rim, or, what I did is order a black steel rim from Rocky Mountain to mount the spare to.
Reactions: swsebek
swsebek
swsebek
2,854
5,832
pa
thanks Tflynn that's what I will do as well.I have a set of foreman rims
Reactions: Tflynn
swsebek
swsebek
2,854
5,832
pa
Yes the studs are smaller but appeared the bolt pattern worked. But I just figured if I screwed the rim up then I may as well have a perfect match
swsebek
swsebek
2,854
5,832
pa
You have to love Rocky Mountain ATV,I ordered the rim ,tire, and fox Nomads mx pants on Sunday and they came this morning.
Reactions: Tflynn
Azcardinal
Azcardinal
14
24
Arizona
I have 28x10x14 tusk terra bytes on 14x7 with 5 2 offset. I keep my stock front rim and tire with me. Stock front will fit front or back. I want to mount and I am currently looking for ideas myself. I also put on 1.5 spacer in rear to help more with tilt. Very happy with setup, rides alot better and safer.
Reactions: swsebek and Mudwing
