P1000 What gun racks are you guys using?
silverstreak
14
10
Morgan Hill, Ca
I've tried them all and came up with this, which I think works great, as long as you don't need a center seat for 3 people. What I did was mounted a V grip stock holder, a very common atv item, on the bar that is just above the rear of the seat. That is where your butt of your stock will sit. Then I used a round pvc plumbing cap and screwed(or glued)it into the recessed area on the dash. You insert your barrel end into the pvc cap and drop the butt of the stock into the V. It holds your rifle with the scope down. It is cheap to do, makes your rifle very accessible, and with 2 people it is not in the way. Been using it for a year now and love it. Your rifle does not move around at all, even in rough terrain. People that see it and have Pioneers go with this and also love it.
ckeele223
25
St. George, Utah
Newbie from Va. here. Just joined the Pioneer club after many years of working on my Polaris Ranger. I have a 2021 Pioneer 1000-3 which will be used mostly around the farm and hunting. Can you guys tell me what best option is for a gun rack? I've seen the overhead racks and m not keen on them? Others?? Thanks in advance, 163bc
Hi Newbie from Virginia, I found Kolpin Stronghold gun boot and Kolpin Stronghold with autolatch mount system to be the best thing for my rifles, I have one set up to be able to mount on the outside of my roll bar on the driver and passenger sides, they mount quickly with 2 u bolts per mount, so 4 nuts and it is installed and then all you do is stick the Stronghold boot in the mount and it locks onto the quick release autolatch, very slick and easy. The largest boot they make will take up to a 55 inch long rifle I if I remember right, I have to remove my bipod on a long range rifle or one of my AR rifles but other than that they are deep enough for most of the other accessories we have. The boot itself is super protective and has a zip up rifle case inside the outer boot so double protection. Check it out I think you might like it. Good luck on your hunt.
Reactions: Biteme and Lady01
Rnyachtclub72
Texas
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Great ideas above and not sure this will help, LOL
1615643304546
Reactions: Lady01
Bighat
Bighat
887
3,795
Gallipolis Ohio
Buggyman
Buggyman
47,009
370,771
ne. ohio
check out company called BLAC-RAC they make some nice gun racks (not cheap)
K
KPM
42
124
Prairieville LA
I did something a bit different that I haven’t seen. Used koplin grip style mounts and fab-ed a pvcmount. Rides “center shotgun”. This is on a p500.
0f524630871959b2423e45163f79b3c1
Lochsa88
Lochsa88
44
154
any pics?
Moxdmguy
60
402
53
Lone Jack, MO
Blac-rac is the route I went, pricey yes but secure and I have been through a lot of rough terrain with no issue. I also use the Seizmik mount in the middle seat.
104CB6D6 F387 4C89 8A52 762F86253412
rudyeng
109
554
Florida
Rudy phone 188
UTV
My Pioneer and Defender. Also did the same 4"x1" cross member on my 22 pioneer. A little more work since I bolted that one to the bed cross members
Best of luck !
Rudy
Reactions: WagginTail
