Wshelton, by your description I am guessing you are mounting the General Grabbers? I have looked into those as well, a perfect little truck tire for the 14" wheels and stock tire height. If you found another, I'm looking forward to hear what it is, but I'm putting a 2 dollar bill on the Grabbers.
So, maybe you or the others here can tell me, what size are the factory wheels? The front tires on deluxe models are 9", so the 8.5 Grabber will fit perfect. BUT the rears are 11" tires, so are they just an 11" inch tire on the same size wheel as the fronts, making it stick out one more inch on each side? Or are the rear wheels actually wider. I think all 4 wheels are the same size, looking for info to see if I am correct. Thanks!
