P1000 What Size Vent lines and how many feet?
Bfree66
47
94
North Louisiana
New to the Honda P1K5 world, picked up the big girl last week, but not new to sxs's though. I've snorkeled everything else ive had. I've read most of the snorkeling threads but no where can I find What size hose do I need for the vent lines? 1/4" is what Im thinking and how many feet? Thanks in advance.
Hucker
67
138
SE AZ
1/4" x 25'+. You will need a couple of 1/8" x 1/4" reducers for the diff vents. Length depends on your routing...
Gas tank vent and sub-trans vents are 1/4"
Front and rear diffs are 1/8"
Some vent the fan vent...that is 1/4"
Some vent the shifter adjustment box...that is 1/8", I believe.
I used 1/4" oil resistant hose for all. You can use a tee to tie the front diff and fan vents together.
I put together a decent list in another thread...somewhere...lol
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Auto parts stores sell a box of assorted vac fittings in one box for less than 10 bucks. I spliced into the stock lines so I could keep that factory seal.
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
I did this yesterday and bought 20' of each size tubing with a little of the larger tubing left over and probably 6-8 ft of the smaller tubing left over. extended 6 vent lines.
Fan
Front Diff
Rear Diff
Transfer case
Gas
Control box
Reactions: pct
T
taylorman
167
97
Lafayette La
Fan
Front Diff
Rear Diff
Transfer case
Gas
Control box
Where did you tie these off at? I'm thinking I don't need to do the front diff since it's so high up in the dash.
ghost
ghost
993
1,874
BC
I ran them up one or the other rear Roll Cage bars up under the corner of the top.
I did the same.
Never plan to go that deep but just do it while you are running lines so you never have to think about when you hit water. It'll only cost you and extra $2.
Reactions: Delton and drfubar
bjd68
19
14
abbotsford B.C.
Can anyone tell me where the adjuster box vent is? Thats the last one I need to find !
Don't forget to put a filter at the top!
20d1a84684480535054caf45994cee55
SIGNATURE:
Quote by Delton: You ain't riding the Bull without some type of collateral damage. Scratches, gouges, etc. But if you do happen to be the type that Armoralls your tires and waxes your panels, we have a nice stretch of blacktop you can raise hell on lmao
Reactions: utvmi and pct
T
taylorman
167
97
Lafayette La
Ran my rear diff and cable box behind driver seat. Ran gas tank and sub Trans behind passenger seat.
Front diff seams high enough to me. Why would I need to change it?
bjd68
19
14
abbotsford B.C.
SIGNATURE:
Thanks ! Where could I find one of those filters for the vent hose?
SIGNATURE:
That's a very good idea!!
T
taylorman
167
97
Lafayette La
The front differential vent seems high enough to me why would I need to change it?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
It's under rear driver's side footwell
utvmi
utvmi
265
574
SIGNATURE:
You got a link to the two filters you used ?
Reactions: sharp
