Wheel lug pattern ?
7,150
27,237
Do all brand of UTV's have same lug # and spacing?
They do not. Honda uses a 4x110 which is 4 studs spaced 110 mm apart. Even Honda wheels don't interchange between UTV and ATV because the stud diameter is larger in the UTV's.
I think Yamaha uses the same 4x110 as Honda but you should check that to confirm.
When ordering wheels, check the back spacing that is required. The pioneer 700 uses more back spacing in the front than in the rear.
I hope this helps.
Joe
Reactions: BULLDOG6
7,150
27,237
I hope this helps.
Joe
Thanks for the reply, guessing all 4 tires and rims identical won't be that easy.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
The wheels from my 12 rancher fit my 12 p5 same size and everything but the rancher has 11in rear rims
The p5 has 10mm studs like the ATVs I think so they should swap. The 700's have the 12mm studs
