P1000 Wheel spacers or not
Mahaffey380
24
11
Union Grove NC
OK, I have heard both ways if I go 14 x 7 wheels on my pioneer all the way around and run 27 x 10 x 14 tires all the way around. Staying as close to stock width (63”) as I can, Do I need a 1 inch spacer in the rear to keep them even or not?
THEOLDMAN
THEOLDMAN
238
351
Washington, North Carolina
I installed a Highlifter 2.5" lift. I added 2"spacers on rear and 1"spacers on the front to keep my stance. I have 30x10x14 tires all 4 corners
G
GWH
748
2,475
Las Vegas Nevads
Assuming ur new wheels have the same offset ft and rear,You will need 1” spacers on the rear.The stock wheels on the rear of the pioneer 1000 ,have an offset greater than the ft.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
14x7 5+2 wheels and 28x10 tires puts me at about 66 to the outside of the tire tread and wider at the side wall bulge and right at 65" to the outer edge of the bead lock. I have a 1 inch spacer in the rear to make the front and rear even. If you want to stay closer to 63" you'll need a 6+1 wheel. The 10" front tire will still bulge a lot more than the stock 9" tire so you will likely be 64 or a bit more.
Reactions: TripleB and Adam490
