P700 Wheel/Tire Set-up
KyleC
KyleC
102
155
Pittsburgh, PA
Has anyone run 27x11x14 & 27x9x14 STI Rocktane tires on 8” wide wheels with a 2/5 offset? I have the opportunity to purchase a used set-up, and don’t want to screw anything up. Owner claims it rubs very little. I have the commander shock conversion, so 2, 2-1/2” lift. The are Camo Vision wheels, and would match the camo P7 nicely.
KyleC
KyleC
102
155
Pittsburgh, PA
That's what I have been reading too. However, I don't recall reading much about an 8" wide wheels with 2/5 offset. Seems the typical wheel width is 7" and the typical offset is 5/2. I'll be honest, I don't understand wheel set-ups that great, widths/offsets/spacers/etc...
jwfirebird
jwfirebird
927
1,446
western ny
dennis kirk
2017 Honda
SXS700M4 Pioneer 700-4
Specs/Edit
  • Drive Type: Shaft
  • Front Tire Size: 25x8-12
  • Rear Tire Size: 25x10-12
  • Front Wheel Size: 12 x 7
  • Front Wheel Bolt Pattern: 4/110
  • Front Wheel Offset: 5+2
  • Rear Wheel Size: 12 x 7
  • Rear Wheel Bolt Pattern: 4/110
  • Rear Wheel Offset: 5+3
William
William
1,442
2,887
Flowood MS
dennis kirk
2017 Honda
Specs/Edit
  • Drive Type: Shaft
Dey wrong... LoL ...
Front 12x6
Rear 12x7.5
Front offset
4.5+1.5
Rear offset
6+1.5....
I think...
Reactions: Backwoods
KyleC
KyleC
102
155
Pittsburgh, PA
Okay. So the wheels in question are definitely 8" wide. Probably 6+2. Not OEM. They are aftermarket. Tires are Rocktane 27x11 & 27x9. Will they fit a P700 w/ a Commander Lift and not rub?
Backwoods
Backwoods
35,776
362,050
Douglasville ga
Yeah they will fit I run 27s stock 0 problems . Commander Shocks give you 2 inches of lift you should be fine
Reactions: ARHUNTIN
jwfirebird
jwfirebird
927
1,446
western ny
wonder where that came from if its wrong, certainly not the first time I'm sure. but they should be fine like he said
