P500 When it's time for 4 wheel drive....
Shifted all four of our Pioneers on the fly without as much as a thought. Turf mode all the way through diff lock, I’m not stopping to shift. Somewhere around 15k combined, broke a lot of other s*** but no shift related issues here. Not saying you’re supposed to but it’ll engage smoothly. I make sure I’m not turning or spinning a tire and slightly easy up on the throttle like a manual in a truck. But that’s me in my machine.
Mudder
Mudder
NTC/TAP Transition Member
11,880
90,564
Wow, thanks for all the replies! I suspected I could shift on the fly as long as all wheels were turning the same speed. Probably will only do this in those emergency "oh crap" moments.
There ya go. Usually slow down at big mud holes to pick my line and shift. And if you ever consider adding the Torqmaster locker, it’s even more amazing what that true 4wd does in the rough situations.
70Bones
70Bones
888
3,779
New Brunswick Canada
The P5 Owner's manual says, "You should change drive modes only when the vehicle is stopped and the engine is idling...Changing drive modes while the vehicle is moving could damage the drivetrain." See page 37 of the manual for more info. HTH :)
It says could, not will. They print that because most people would damage the drivetrain otherwise. If the driver is aware of what is happening inside, and makes sure there is no load on the drivetrain, it will cause no damage.
K
kensmithjr
14
24
Prattsburgh, NY
It seems like the P5 computer decides when to actually engage the 4WD. If that's the case, you probably can't hurt it.
Mudder
Mudder
11,880
90,564
The 4WD shift arm on the front differential does have a spring on the shifter cable for a little play while the gears mesh. The same spring that I almost forgot when installing the front locker. 2017+ Computers only handle shifts in the auto mode or to down shift when slowing down in manual mode. 4WD engagement is pure mechanical by the driver. Computers also retard the engine briefly during shifts, that little hesitation at shifts.
