Tramguage1
Texan
Well Captin jacka and I are loaded and ready to pull up in the a.m.
Don't forget diffs. But it's probably all the bud light you and a-dam go through.
Drive safe Tram. See you there.Well Captin jacka and I are loaded and ready to pull up in the a.m.View attachment 430258
All you wrench monkeys, I know you're eager to get to Takeover. Please double check your work, have seen many occasions of loose to missing nuts, ergo bolts come out on the following: A-arms both mount and camber adjust nuts, shock mount points, wheel lug nuts. Make sure your brake lines and wiring is properly routed and in no pinch point. This can save you from having avoidable issues 30 miles from BFE and affecting the entire group. A simple double, triple check saves a lot of potential grief.
I legitimately think to myself as I'm working on it that I really should double check everything because Jackal is going to bust my chops if this s*** comes loose on the trail.
You must have taken a page out of Can Ams book….they freaking put lock tight on every nut and bolt no matter what it is attached to….and they use a poop ton of it. Breaking more crap trying to put parts on than I have on the trails!!I put loctite on every bolt I touch now.![]()
I had an A arm bolt back out one time sooo I need reassurance lol !You must have taken a page out of Can Ams book….they freaking put lock tight on every nut and bolt no matter what it is attached to….and they use a poop ton of it. Breaking more crap trying to put parts on than I have on the trails!!![]()
This is great advice and will make the days easier….but I somewhat have to disagree because if we all had our stuff fixed right when we came, then what the hell would we all talk about and who would we make fun of at night or on this forum. I mean @TripleB has been doing trail fixes for the last who knows how many years. If he didn’t do that then all he’s got is cool hair.All you wrench monkeys, I know you're eager to get to Takeover. Please double check your work, have seen many occasions of loose to missing nuts, ergo bolts come out on the following: A-arms both mount and camber adjust nuts, shock mount points, wheel lug nuts. Make sure your brake lines and wiring is properly routed and in no pinch point. This can save you from having avoidable issues 30 miles from BFE and affecting the entire group. A simple double, triple check saves a lot of potential grief.
And yet you still might be that guy….This is great advice and will make the days easier….but I somewhat have to disagree because if we all had our stuff fixed right when we came, then what the hell would we all talk about and who would we make fun of at night or on this forum. I mean @TripleB has been doing trail fixes for the last who knows how many years. If he didn’t do that then all he’s got is cool hair.And then there is @Adam490….well I don’t have enough time to go into his crap!!
but Like for example a month ago @Hondasxs had his ball joint bolt come off during our ride. That alone allowed me to have a great father son discussion that went like this…see Richard show up for a ride, see Richard forget to look over his ride, see Richard broke on the trail with a hole in his front diff, don’t be a Richard!! That lesson was priceless!
And then we had an entire thread about it. This site was not built on responsible adults being prepared and avoiding the worse, it was built on dumbass drunks destroying things no responsible adult would do!!!
Thanks for the reminder @JACKAL , as I did just go out and check all my stuff so I wouldn’t be that guy!!LOL
At least spit on itThings needs a bath
I sprayed the big s*** off it last week. Just gonna get dirty again lol. After we shotgun a couple beers you'll never notice the dirt.Things needs a bath
