P1000 Winch and mount questions
JoeyL
JoeyL
276
741
Houston
Just an update.
NOW Warn states this mount
Will accept the VRX 45S and the Axon 45 on the 2020 Pioneer.
Not sure what changed, as before they said only the VRX world fit.
Sent from my XT1635-01 using Tapatalk
I used this mount for my Axon 55.
Had to cut parts of the bumper to clear the ends of the winch and slot the holes for the hawse and move it down to make it work.
2e9716b7db6da3641202344ba2423f68
Not the greatest pic but you should be able to see the corner I cut out of the bumper.
Reactions: Biteme
ProudDadOf5
ProudDadOf5
3,121
24,200
Winfield, WV
I’m not sure enough to say, i think it could be done but you’d have to drill new holes to mount the winch in that position.
Nah, no need to.
Reactions: Biteme
P
Pilot2016
118
173
Rockhill Sc
I installed the viper elite and I’m pretty happy with it so far. My free spool knob is on the drivers side.
Viper Elite 4500 Winch Install
That’s interesting. I have a 2018 P700-4. I bought the Viper Elite Widespool 4500 and the mount I bought with it, requires the winch to be upside down and the freespool on the passenger side????
Go figure!!!!
But.... it works great!!!
Reactions: Biteme
Formula1
Formula1
160
264
SE Missouri
Well I had it all planned out, HF has their new 5k winch on sale and I was going to buy the EMP mount from a member on here. I just called EMP again to ask a few more questions and I was told their mounts are only rated to 4k lbs. I didn't read this on their site it just came up in conversation. Back to square one!!
Reactions: Biteme
ToddACimer
ToddACimer
Pioneer 1005-2
3,736
15,794
Oshkosh, Wi
Take a look at the Warn winch mount
Reactions: Biteme
Formula1
Formula1
160
264
SE Missouri
I did, mounts the winch upside down. Im thinking ill just buy a new front bumper. I like that Tough Country but it seems they are out of stock at the moment.
Reactions: Biteme
Formula1
Formula1
160
264
SE Missouri
Will a widespool 5k or 6k fit on a tough country bumper?
Reactions: Biteme
Formula1
Formula1
160
264
SE Missouri
Thank you! It looks like the dimensions are the same on all of them so I should be good to go. Side by Side Stuff is showing the bumper out of stock so im guessing that will be the case everywhere. I'll get the winch on order and wait for the bumper.
Reactions: Biteme and TripleB
TripleB
TripleB
16,235
146,976
Caryville, Tennessee
My bumber was on backorder for about 6 weeks. That was 2 or 3 months ago. I have the slasher bumper on my 5 seater and the tough country bumper is way better built and looks better also. IMO
Reactions: Biteme
U
Ugly
East Tennessee Mudder
387
894
Rocky Top
Looks like Tough Country makes ATV bumpers for Pioneer 1000: 2016-2017(from their web site). So they do not make Honda bumpters for Talons or other models of Pioneer?
Reactions: Biteme
E
Ethan
29
76
Tucson
I got the viper elite 4500 wide spool winch and a Kfi Mount. I’m reading that this Mount isn’t the best position for the Pioneer 1000. Should I get the warn Mount? Will it work with the Viper? Thanks
Heinecke2
Heinecke2
42
119
Illinois
I have not used the factory Honda mount. I have used the Warn mount at it fits well and makes the winch fairly easy to reach despite being upside down.
By comparison I previously had the KFI mount and I struggled to keep the bolts tight after hard winch pulls and the cable angle is poor. The winch was tough to free spool.
I currently have the Warn winch bumper and this makes winching easy and the mounts are nice and line up well with the frame
My last front bumper was an RD front bumper and the fit to the stock mounts was poor, the upper mounts were flimsy and the bumper wasn't a great fit to the machine. I smashed the front skid plate on it the first time out and tweaked the mounting brackets. I ended up making my own mounts and modifying the bumper a lot to make it less flimsy. In the end it was much improved but not worth the cost
How is the rope angle with that warn mount. I have the KFI and it is aweful for rope angle. I've seen pics of the slight rope angle with the EMP mount but couldn't find pics of rope angle with the warn mount..
Tldrigg
Tldrigg
16
31
Reno
This is what I went with. No problems and everything just bolted on.
Heinecke2
Heinecke2
42
119
Illinois
I have the warn vrx45 with the same KFI mount from your link. Install was simple but the rope angle coming off the bottom of the winch with that mount can't be less than 25-30 degrees...
The other thing I don't like about that KFI mount is I get a pile of cocaburs and other stuff piled up right at the base of the winch. When I pull with the winch that crap then gets rolled in with the rope. If I had a cable maybe it wouldn't bother me so much but I feel like it is hard on the syn rope
Reactions: Tldrigg
E
Ethan
29
76
Tucson
I never installed my KFI mount and instead got the warn mount and it was very easy to mount to the bumper then the frame with the viper elite 4500 synthetic winch, but it does get mounted upside down. So far no problems and it has a little angle when spooling.
