P1000 Windshield Washer Jug
MuddHonda
MuddHonda
55
159
Fredericton, New Brunswick, Canada
Has anyone tried to install a washer jug under the driver's seat with the filler tube coming out so you don't have to remove the seat to fill it. Or does anyone know the vehicle make and model that would fit?
Washer Jug
Vikes79
Vikes79
SKOL!
11,773
114,166
South Dakota
  2. Talon X4 LV
I’ve seen this style used before on utvs. I’ve seen one under the dash where a spare battery is often used.
if you mount the tank where you mention, that’s a big run for that little pump.
Reactions: Isaiah
chadwick
chadwick
10
Coopersville, Michigan
Did you try this mounting location for the washer reservoir? I have the same washer tank/pump and dual battery set up and was thinking this is the only option left? Thoughts?
MuddHonda
MuddHonda
55
159
Installed a washer jug from a Hyundai Accent under the seat, have to remove the seat to fill it. I had to shorten the filler tube and make a bracket to hold the jug.
Pic 1 Pic 2 Pic 3
Reactions: TripleB
