P1000 Wiring 7 pin rocker winch swith from factory Warn Winch
E
et1984
11
Minnesota
Hey everyone,
I am new to this club, but I am need of some help. Can anyone share a video or diagram about how to wire a 7 pin aftermarket rocker switch from the factory Warn contactor. I currently have the factory set up with the remote from honda, but would prefer the rocker switch...or both if that is possible. Thanks
115,818
Yep, here you go!
Welcome to the club from Michigan!
Pics Or It Didnt Happen!
of the machine ;)
1E42B540 551B 4CA6 80EE 029BE3AFCCF4
Reactions: Lady01 and TripleB
E
et1984
11
Minnesota
Thank you. I wired it just like the image on the left... but i noticed your image does not jumper terminal 3-6 and 1-4 as the photo i shared. What is the correct way? And if i have the dual battery set up with the fuse box, but the winch was installed by the dealer before hand it run off the main power can i run this switch power to my accessory fuse box for power or no? Lastly, for the image i shared of the contactor(this is the one i have) i assume the brown or center terminal is "common"...so what do i connect there from the switch...and the winch out will be from green to 4 and winch in will be from blue to 6?
Appreciate the help here...First time doing this and the factory winch install is throwing me off....(installed before hand)
Capture Warn contactor
Reactions: Lady01
WagginTail
WagginTail
1,585
5,880
SC
Here's mine. Small gray wire is ground going to rocker switch. Small green and black go to the rocker switch. These are your in/out. Don't remember which is which. Your rocker switch is different than mine. My positive coming to switch is jumped to the positive for the top and bottom lights. My ground coming to switch is jumped to the ground for the lights. Hopefully you're not more confused now
20211018 193655
115,818
Sorry Bud i was in my tree stand earlier.
Just like @WagginTail just posted should take care of what u need
