Wiring a second battery
dalis7393
44
37
Hello All,
I can use some help. I want to set up a second battery and i want to do it so all accessories run only when key is on. I was thinking of using a stinger but instead of hooking up each battery to each side of the solenoid, can i run each hot to the same side of the solenoid and just have the new accessory fuse block on the other terminal of the solenoid? If i hook it up as shown on instructions, the accessories would always be hot going off second battery saving the primary for starting. I could use some recommendations on setting up so everything is powered up when key is on. I have a 700-4 deluxe and my buddy has the pioneer 1000-5. Thank you.
Reactions: TxDoc
Hillbillytnt
Hillbillytnt
552
2,030
Ky
Not sure what u are asking. The aux battery is the only thing hooked to stinger. One side is from bat to stinger other side is stinger to fuse block. Two small posts are key on and ground.
Reactions: TripleB
dalis7393
44
37
i guess my question is when hooking up the second battery, do i still use an isolator for the 2 batteries and then still use the stinger from the second battery to the new fuse panel i am installing? i want to wire this so i get both batteries charging up properly and still have all accessories ran only off second battery only when key is turned on.
Hillbillytnt
Hillbillytnt
552
2,030
Ky
Sounds like you have it. The pioneer is ez to install a second battery. Just hook the second ground. Blue taped wire to the 2nd battery and run a hot wire between the batteries. They will both charge. The stinger controls the 2nd fuse block. If hooked to a key on wire it will only make the connection when key is on. The isolator is just to protect the main battery from being run down past a certain voltage. The key on switch from the club store makes things a lot simpler. Run it to one small post on stinger other small post to ground then big ones are power in and out. Everything on that fuse block is key in only.
Sheetmetalfab
Sheetmetalfab
2,227
14,033
Alaska
Hello All,
I just hooked everything in parallel.
No stinger.
Accessories powered from both and key activated.
So far no issues.
