P500 Wiring Help
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
So I have the accessory subhsreness plug on my P5. I have MicTuning winch rocker switch and a LED on/off rocker switch. I have my winch working correctly with the rocker switch but for the led light where does the negative wire from light go? The back of switch only has a place for the positive wire to light but what about negative?
81D02038 E269 45E0 A03E 4E8D2FA2EB99
13,568
67,623
I would suggest a ground bus bar, with a nice 6 or 4 gauge wire going directly to either battery or engine block.
Place bus bar under your hood for future ground connections. You could also route your grounds from your switches to the bus bar.
Edit: Pick one in your price range
https://www.amazon.com/s/?tag=sxsweb24-20
GRANITE
GRANITE
1,100
5,550
Brookville, Indiana
The negative from the light goes to a known good ground. It does not need to be grounded at the switch.
What about hooking it up to one of the connections on the 4 available hot wires with the ground wire? Thanks for the help...
13,568
67,623
Sounds like a known good ground to me!
Reactions: GRANITE
