I'm a lil con fused wiring the meters for the 2 meters that came with my TRUE UTV BATTERY ISOLATOR KIT. There's 2 meters an a relay or w/e it is. Don't get how it should go.
The green wires-one goes to the dark gray and one to the light gray. Red wire from the relay to a power on wire or 15 acc fuse wire in the fuse box. The other 2 red wires go to each side of the isolator. Black wire to the ground of the accessory battery or to metal frame. Then connect each of the red wires to each of the meters then the light gray wire to one then dark gray to one.
