P700 2020 p700 stalling when put in drive
A
Ariestmh
Colorado
I wonder if something go wet? check all the molex connectors. They can get wet and hold moisture for a really long time and cause issues
Like Remi said check connectors and spray with WD 40 before re connecting , About the only good thing I have to say about WD 40, great water dispersant. That should start a fire storm!
Thank you for the help I will look into it and see what is going on.
41,840
Yes the dash is rebooting like when the key gets turned on. Sometimes the screen reboots in neutral but does not die it wants to die but it doesn’t . When it’s put in drive it dies and the screen reboots.
I would check those grounds for sure.
You uncle isn't alone with this. Check this thread out...
A
Ariestmh
Colorado
Thank you. We ended up wiggling the ground wires and a couple connectors and it is running fine now.
