P700 2021 700-4 deluxe spanner tool
Rigit
142
354
Nla
I need to adjust the rear shocks on my 700-4 deluxe and after looking at so many spanner tools I figured I better ask the question to be sure to get the correct one. Is there anyone that has used/purchased one that fits and works as it supposed to? I have seen some get one and then find out it didn't fit exactly right and was difficult to use. As usual thanks for the responses and the wealth of knowledge that is always shared on this site.
Reactions: CID
5,052
22,663
I have the same question for a Talon. 🤔 The service manual doesn't show one (unless I'm blind o_O).
HondaTech
Fox sells the correct ones for the adjusting and lock rings.
Make sure you get the correct one for the shock size (2 vs 2.5)
Reactions: CID
Rigit
142
354
Nla
Thanks HondaTech. Is the Talon and pioneer the same size?
HondaTech
The "Normal" shocks on the P700 and most other Honda atvs should take any standard spanner wrench, there are adjustable ones as well.
The Fox wrenches are for their shocks only.
Reactions: CID
