P1000 30inch tires
BigOL3
BigOL3
2,994
8,919
I realize that is not your video, but hope you might have the answers.
1. Near the end of vid, he add 2 more rivets from the inner wheel well. I could not tell from the vid, to what were they being anchored since there was not upper lip on the replace part?
2. Wonder why the replace plastic part did not have an upper lip made on it, rather than relying on just silicone?
Isaiah
Isaiah
2,191
6,964
Altamont TN
Isaiah, of course it will.
Well it might work but when I had 30s they didn't rub there. The blue circle is where the problem was on mine
20210514 1731312
TimG
TimG
OLD SKOOL
774
3,814
Southern Indiana
I’m running 29x9x14’s with super atv a-arms and 1-1/2” spacers at the front and 2” on the rear with 29x11s. No rubs at all. Was told I could run 30’s with this setup, any thoughts?
Different tire makes will measure differently but any 30 inch tire should work with your set up. I was running 29'' Bighorns on a stock set up. I'm currently running 30" Terrabytes with SATV arms.
Robobrainiac
Robobrainiac
2,475
8,664
Hey all I’m new here. I just recently bought a set of 30inch mud terrain tires and 14inch rim. I have a totally stock suspension and they are rubbing the plastic that is also the floor board. In just the front. What can I do to fix this minus lifting it? Thanks!
You need forward control arms.
SuperATV makes some arms as well that will do the same thing.
TimG
TimG
OLD SKOOL
774
3,814
Southern Indiana
Just for clarification, SATV arms = Super ATV forward arched A-arms. The only A-arm Super ATV makes for the Pioneer 1000 front.
Reactions: Robobrainiac
Rmajrfullforce
5
Las Vegas, NV
  1. Looking to buy
New here. In route to purchase a used 2017. Many state here to but forward a-arm to increase the size to 30, he about rear a-arms? Is that needed?
108,204
Okay thanks. Also while I got you here. What’s y’all’s opinion on the cfab forward arms that provide lift also?
I have none on those. I have SATV arms and use the preload on my shocks for lift. If u still have stock shocks, better upgrade either way with arms
