350 Rancher Engine problems
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
Air coming back through the carb = intake valve. Exhaust = exhaust valve. Oil fill cap = Piston and/or rings.
I've saw valves stick open from lack of oil and heat. The little valve springs are pretty soft and it doesn't take much for them to stick in the guide.
how hard would it be to stop the piston at the top of the stroke just using the electric start?
Deleted member 3748
What would this indicate?
And also, how hard would it be to stop the piston at the top of the stroke just using the electric start?
Very difficult to stop the piston at the top with electric start.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Doesn't it have a pull start also?
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
So you’re telling me... that if I take a ball peen hammer and hit the sides of that engine enough times and in enough places, that this problem will go away?
41,981
It's like a leak down test without the flow gauge, but it will tell you what you need to know.
I've seen pics of my own colonoscopy. They were s***ty.
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
Alright guys.
1. Took pin light and watched until top stroke of piston. (Using recoil pull)
2. Hooked up compression test hoses to air compressor.
No leaks. @100psi. I let it hold for 10 minutes.
I pulled the air box and put my ear and face down to the carb intake.
I put my ear to the exhaust pipe. Didn’t feel or hear any air escaping.
I even went as far as to spray the entire engine w soapy water I use to find holes in tires.
Why will it hold 100psi, but not crank out but 20 ?!?
Also, I RETESTED the compression gauge against my air compressor’s gauge. It matched.
Idk
Reactions: DG Rider
Deleted member 3748
Alright guys.
Idk
Hmmmm... did you test the compression again using the compression tester by itself?
41,981
Alright guys.
Idk
Is it cranking over at what you'd consider a normal speed?
Pull the breather tube off the crankcase and listen there. You should have heard this through where it enters the airbox/air filter, but maybe the filter hid the noise. Keep in mind that we're not talking about huge rushes of air unless you had major engine damage. A subtle hiss most likely.
Reactions: JsheII3
Deleted member 3748
Alright guys.
Idk
I'd try it again with the cylinder at the bottom. If it holds compression again, I'll be surprised.
Deleted member 3748
But you'll have to catch it on the compression stroke (when both valves are closed). On the intake stroke, the intake valve will be open, and on the exhaust stroke, the exhaust valve will be open and letting air out.
I found a cool graphic. :D
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
Well, that’s the thing... since after a few mins it didn’t leak, and still while hooked to air compressor, I slowly pulled the start rope to see if something, somewhere gushed out. I pulled really slow and deliberately. And a full revolution. Nothing.
Deleted member 3748
At one point it should have shot out of the exhaust.
Giphy1
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
Also, worth noting...
With my pin light I could see the piston going up and down as I pulled the recoil.
It was all grimy on top.
Deleted member 3748
I agree.
And I’m not aware of any oversight.
I understand the basic theory of the test.
Could the piston have dropped? So that compression is low at top of stroke, since top of stoke isn’t high and tight?
I guess a bent rod could do that. I'm wondering if we ignore the compression test results and check for both valves closed all the time and the camshaft is smoked like @ByronM mentioned above.
Similar threads
Pioneerpilot
Replies
Views
761
Replies
15
Views
3K
K
Replies
Views
3K
allgm1
